Buzzing from dome light
does anyone else's dome light buzz when they open the door and it is on? mine makes a weird buzzing/ringing noise. do i need to get a new bulb then?
its not normal, my BRAND NEW 04 did it a day after i got it, wasnt too impressed
but brought it back to the dealer, they fixed it up, doesnt do it anymore...............but damn was it annoying!
get it fixed, there is definately something wrong
master of the culinary martial arts
Some bulbs buzz. Some don't. My factory bulb buzzed, then I replaced it and the noise went away. I replaced that bulb with a colored bulb and the colored bulb buzzed. Colored bulb burned out and I replaced it with another colored bulb from the same company. That bulb doesn't buzz.
Custom Titles are played out
Originally Posted by HustleLikeM0FO
that buzzing isnt exactly buzzing. if you listen close its the nawzzz spooling up creating that buzzing sound in your dome light
He accidentally wired his nawz purge valve into his dome light
Maybe if he hadn't gotten his dcsports header with his t4 turbo dominac and aic controlled air intake, he'd be okay.. but he had to go fast and furious...
he was purging the nawz out of his dome light...... i tried to tell him to run his purge lines to his washer nozzles but noooooo, he had to run them to the dome light whcih he now fvcked up
fvckin gl00b..
maybe you should have done it for him instead of making him look like a n00bular gl00b..
beveragemp
May 25, 2015 07:11 PM
twtron
Apr 17, 2015 12:09 AM
meels808
Nov 5, 2001 09:15 AM
