How about this setup?
Old Oct 22, 2004
DodgeNeonSRT-4's Avatar
DodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of lightDodgeNeonSRT-4 is a glorious beacon of light
I've dealt with two 7thgens with k20's...one boosted and one all-motor. both have done just about all you can as far as the motor goes but their performance still comes up a little short of what I've seen in other cars.
so how about this setup (availability of parts, price, and level of fabrication needed are not an issue)
k24 + k20 heads + boost + 6 speed short-throw tremek
any takers?
anyone wanna try this all-motor instead of boosted?
Old Oct 22, 2004
nindoo's Avatar
Why is my vagina bleeding?
If yor paying, and replacing my hood so that it will clear the k24 lets go for it!
Old Oct 22, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
If you gonna use k20 head would that raise compressiona lot, that setup would be better for N/A wouldnt it???
Also for boost would longer gears be better (5-speed) since youd be probably running through the gears faster, for N/A 6-speed
Old Oct 22, 2004
the head could be easily modified for either N/A or boost. the only reason I would be using the 20a head on the 24 is because the 20 has the better power for the long run (the k24 has the torque for the quick get-up so the head combo is a compromise I have heard people running)
we could mix the gears in the 6 speed up, I just prefer it for the amount of power this motor would be producing. a 5 speed wouldn't allow for as much top-end in my opinion.
and yes, the hood is getting a blister, lol!
Old Oct 22, 2004
cosmo's Avatar
cosmo is an unknown quantity at this point
I don't get it, are you going to try and sell the set-ups or are you looking for a guinea pig vehicle? If you want something to swap into sign me up .
Old Oct 22, 2004
it's just an idea I'm tossing around for my vic...
seeing as how the k24 is the largest displacement factory honda motor...(4 cyl)
Old Oct 23, 2004
after doing a little more research, I've found two examples of the motor + head combo
one is N/A producing 185hp at the wheels
hasport's is blown producing 275 at the wheels
Old Oct 23, 2004
the final compression ratio is 9.6:1 so it should be fairly easy to boost (my neon was stock 9.8 and daily driven at 20 psi)
now I'm compressing 11.1:1 and running 25 psi at the track (daily driven at 19 psi) and the motor is still fine, we'll see how this one holds up
so long as you can supply the fuel and you know ignition, you should be able to compress a billion:1 running a billion psi (up to a certain point where the block goes Kaboom! lol
Old Oct 23, 2004
nindoo's Avatar
Should be more than that a stock rsx type S produces sometging like 178 wheel HP. But I'm not sure on that.
Old Oct 23, 2004
also there is a diferencen between the Accord k24 and te CRV one, the CRV's has toque lower in the power band, and lower compresion ratio, one is 9.6:1 and the othet is 9.7:1
Old Oct 23, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
If you have the money great
Old Oct 23, 2004
HondaLuver's Avatar
Its a celebration bitches!
yup... its a good combo, its goign to fit in my car no matter what... even if i have to go hoodless
Old Oct 23, 2004
it would be the one from the crv...sorry I thought I implied that. the k20 heads will help it breathe a little better on the top end (the only criticism of the k24)
no, I don't have the money, lol. but it's what I might advise the girl to do.
her current boosted k20 7thgen is a tad underpowered in both of our opinions
Old Oct 23, 2004
haha. I'm sure a hood can be made up. carbon fiber anyone?
Old Oct 23, 2004
just a little thought, why don't we go all out with this.
type R inspired...appearance at least...
right hand drive
true dual exhaust (as in split the header flange in two...would require twin turbos lol!)
now that would be a one of a kind show car, lol.
four cylinder twin turbo
Old Oct 27, 2004
one of the kids I was talking about (the boosted k20) has decided to put a little more research into this project.
he's found a k24 with 8000 miles on it, apparently from a total wreck. told me he was going to have to put out $8000 for it. sounds a little pricey to me, but for that kind of speed I think I would pay it too.
He's going to use the k20 parts from his current motor and the current t3/t4 turbonetics hybrid he is running. e-manage and e-01 to start...
I'll keep more info posted if he actually goes through with it
Old Oct 27, 2004
MadWheel's Avatar
Premium Boosted Member
For all-motor I say stick with a K20. For boost, the K24 would be sweeet. I have a 2.4L now, and can't wait to boost it!
Old Oct 27, 2004
someguy's Avatar
someguy is an unknown quantity at this point
i read in a mag one time about this combo. with the k24 block k20a2 head and a hondata was running about 220-240hp(not sure about the 240). that was n/a, dont remember compression ratio or anything like that. also they didnt use a head gasket...just honda bond between block and head...same with oil pan(i think). it was a sweet setup.
Old Oct 27, 2004
dezod's Avatar
7thgen Power Maker
Def K20 for N/A
I have seen almost 220 WHP off of bolt-ons from the K20
I would still say K20 for boost over the K24. More internals are readily available and the K20 has been proven to be failry reliable under boost as well.
Old Oct 27, 2004
2.4L > 2.0L
Old Oct 27, 2004
icebergslim's Avatar
BOOSTED HYBRID
icebergslim is an unknown quantity at this point
who sells pistons and rods for the k24?
Old Oct 27, 2004
forged pistons?
what kind of rods? shotpeened or forged?
Old Oct 27, 2004
wiseco for forged. custom pistons, rods, and rings. [well, not truly custom...but that is how they are ordered...]
this k24 is going to be a huge overbore and resurfacing if the project is undertaken so I'm afraid not much in this area is going to apply.
