question about wiring
Old Oct 20, 2004
Adawg's Avatar
Adawg is an unknown quantity at this point
i spoke to a tech guy who told me that i could run 8gage wire from a distrobushing block to two amps. after searching, i found people saying that its better to use 4gage to run amps. whos right?
Old Oct 20, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Technically, both. Depending on the amp of course, but for the most part you'll want to use at least 4awg wire to run from the battery to the trunk. Once your in the trunk, however, it's usually ok to use 8awg if you want. The difference is in the length of the run. The 16 or whatever feet from the battery requires a heavier guage. From the block to the amp, only 2-4 feet, can sustain a smaller gauge.
Old Oct 20, 2004
darklegacy540's Avatar
darklegacy540 is on a distinguished road
In my car, I still used 4 awg from the batteries to the distribution block and 8 awg from the block to the amps.. the distance of wire from my batteries to my amp is about 10 inches haha But I just used 4 awg for more show. I could get by with 8 awg and not experience any problems..
But in a normal situation, yes using 8awg from block to the amp is okay. But when in doubt, go bigger because it won't hurt it if there's overkill in how big the wire is.
Old Oct 20, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
^^^ what they said.
Old Oct 20, 2004
shmik1's Avatar
yup, my setup is the same.. 4ga from batt to distro blocks and 8ga from blocks to amps...
juror
Jun 9, 2015 02:15 PM
werdnahall
May 17, 2015 11:37 AM
pincookie1
May 4, 2015 12:22 PM
viper775
Dec 9, 2001 10:52 PM
klam
Nov 16, 2001 03:36 PM
