power inverter suggest & questions...
Old Oct 18, 2004
djspot's Avatar
fuk tha man!
djspot is an unknown quantity at this point
any recommendations...
also is there a way of having an inverter that is hooked up so that i comes on when u turn the ignition and off when u turn off the the ignition???
and I wanna run an xbox...so how much power of an inverter should i go for?
Old Oct 18, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
yes jusr run it to the ignition wire in the column, double check me but off the top of my head i think its black w/ yellow.
as far as how much power, u dont need much a bottom line inverter will be enough power to run an x box.
fyi: mines under my drivers seat so i can plug other things into it (easy accessable), along with my ps2.
Old Oct 18, 2004
djspot's Avatar
fuk tha man!
so I'll run the power of the inverter to the ignition wire...so if my inverter comes with the cigarette connector I'll be cutting that off and wiring it to the ignition wire??? to my knowledge it will have two wires, so the live wire I wire to the ignition wire, and the ground I just obviously ground, right?
Cajunkev1
Apr 3, 2017 04:32 PM
Jeffdp
Jun 18, 2015 06:18 PM
Reginator
Jun 17, 2015 07:54 PM
SalPal
Jun 3, 2015 03:44 PM
Supramk3
May 11, 2015 07:55 PM
