205/55/16
Old Dec 7, 2001
Maximus's Avatar
Maximus is an unknown quantity at this point
205/55/16
What do you all think about a 1" to 1- 1/4" drop, and a 205/55/16 set up? I want a bigger size wheel (I got the stock 14's), but don't want to sacrifice acceleration or ride comfort.
Old Dec 7, 2001
SpeedRacer's Avatar
SpeedRacer is an unknown quantity at this point
check out the tire calc. you'll see that a 205/50/16 is a little closer to the stock specs. they don't rub. i've got 205/50/16 with a 2.5" drop and have had no problems at all. but keep in mind anytime you put thiner tires on a car your going to feel the road more (bumpy). hope that helps you out.
Old Dec 7, 2001
klam's Avatar
klam is an unknown quantity at this point
I am planning to get 16x7 alloys in the spring, I'm currently deciding between 205/50/16 or 205/55/16. Only a few people seem to have these sizes, but both are close to stock. I'm not planning to do any suspension modifications so I want to maybe stay with 205/55/16 just to stay comfortable on the road and reduce fender gap. I think 205/50/16 migth have too much fender gap, and 205/55/16 might be ok since it is fairly close to stock.
205/55/16 will definitely improve steering response over the stock, and you'll get a wider footprint for grip. The only concern is weight, I wonder how much of an effect it'll be to have that extra 4-5 lbs per wheel (incl. tire increased weight).
N.B. Stock size 185/70/14 is closer to 205/50/16. Stock size on EX/Si is 185/65/15 and is in the middle between 205/50/16 and 205/55/16.
Old Dec 7, 2001
01CivicMike's Avatar
01CivicMike is an unknown quantity at this point
I ran into the same thing on my EX. The 16's are in between sizes..the true replacement is 215/50/R16. I went with the 205/55's and a drop is very much possible.
Mike
Old Dec 7, 2001
klam's Avatar
01CivicMike: How do you like the ride on 205/55/16? Do you feel slower because of the increased weight? Does it look good or is fender gap large?
yeabmx
May 13, 2010 09:37 AM
civicex01
Oct 19, 2007 07:18 PM
DaMDaM
Oct 26, 2006 10:42 PM
5minutemajor
Aug 12, 2004 02:51 PM
CivicMexicano
Jun 16, 2004 03:17 PM
