for those with boost
Old Oct 14, 2004
maiden4ever's Avatar
maiden4ever is an unknown quantity at this point
do you think the throttle body heater is something to take into account with a boosted civic? im not too sure if it actually heats the air enough to matter, but it seems like a heated throttle body would decrease the effectiveness of an intercooler, whose purpose is to cool the air. does it heat the air enough to warrant the by-pass mod?
Old Oct 14, 2004
oh well, i did it anyway, time to find some mustangs
Old Oct 14, 2004
drjvic04's Avatar
drjvic04 is on a distinguished road
WTH are you talking about?
Ive never heard of that. Give us some details whats it supposed to do?
Old Oct 14, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
nope the throttle body heater isnt enough to heat the air going into the intake, but with winter around the corner id hook it back up even though some people havent had n e prob with it freezing. but it would suck for it to freeze and honda obviously found the need for it to b there!!!
Old Oct 14, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
look in the DYI section. is antifreeze that passes trough the TB to keep it warm in cold weather im also wondering if it heats it up that much...
Old Oct 15, 2004
drjvic04's Avatar
No man
It cools the throttle body at those temps. To us it may seem hot but when the turbo is charging the intake the temps are way higher. If you bypass it the intake air temp will be way higher. You'd probably end up warping the TB and get an air leak. It acts as a medium for heat transfer.
Old Oct 15, 2004
MadWheel's Avatar
Premium Boosted Member
keep it hooked up.... it's just a small enough amount to prevent your tb plate from seizing up... and makes no diff on a hot day...
leave your car as functional as possible, that mod isn't necessary
Old Oct 15, 2004
opto_isolator's Avatar
Once again - it has nothing to do with preventing "vapor lock" or other mysterious gremlins from messing with the throttle body. The IACV (idle air control valve) controls the cars idle. The coolant lines that run to the IACV tell the ECU when the car has reached operating temperature, and actuate the IACV to close. If you take the cooling lines off, you may effect how the car idles. Search, read, learn - there's about 10 threads containing this - all from people who don't read....
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
Tommy Cohen
Jul 22, 2015 07:54 PM
