Sponsored by:
Sponsored by: CARiD
cheap short shift adapter
Old Oct 7, 2004
suthrninca's Avatar
suthrninca is an unknown quantity at this point
Bought a short shift adapter off ebay. Adapter cost me $8.50 and I got raped on the shipping ($15.00). Still, only cost me $23.50.
Old Oct 7, 2004
Mr.Modify's Avatar
cool...let us know how it feels.
Old Oct 7, 2004
thrash_273's Avatar
deploy,engage,destroy.. to fail is not an option
thrash_273 is an unknown quantity at this point
life's good.
Old Oct 7, 2004
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
I ma curious to see how it feels for ya
Old Oct 7, 2004
suthrninca's Avatar
Not a perfect fit. It's binding on the weld of the oem cable mount. That's an easy fix though, I'll hit it with the dremel in the morning. I was able to hold it all together and shift between 3 and 4 while holding a measuring tape. Original shift distance was 5" and with adapter it looks like it's gonna be 3". I think that's a 40% reduction. Any thoughts about cutting an inch or two from the shifter itself (between **** threads and bend in shifter shaft)?
Old Oct 8, 2004
suthrninca's Avatar
Got it installed. Works good. Only bad thing about it is that there are no set scews or other means of fastening it to the shifter besides the cable linkage pin. But it's a pretty good fit regardless. I also cut an 1.5" out of the top part of the shifter and had my friend weld it back together. Now the **** sits nice n low and shifts are firm.
Old Oct 8, 2004
varmin's Avatar
just a troll who likes to laugh at YOU.
varmin will become famous soon enough
sounds like a lot of work, but the price is right.
Old Oct 8, 2004
Wolfgang5884's Avatar
Not bad for that price...Worth the work I guess.
Old Oct 8, 2004
SomeDoodToo's Avatar
SomeDoodToo will become famous soon enoughSomeDoodToo will become famous soon enough
I DID
Old Oct 8, 2004
suthrninca's Avatar
Not that much work. Less than 2 hours. I even shortened the boot. It was worth it!
Old Oct 8, 2004
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
Sounds like you like everything. I ordered one just a few minutes before I saw this thread. What do you think of the quality of this one:
I hope it fits well. Sounds like I spent a dolllar or 2 more than you, 19.95 + 5.50 shipping. But atleast this one has a set screw, infact i think its identical to the arospeed one just with a logo stamped on.
Old Oct 8, 2004
CapYoda's Avatar
Escaped Convict
oh what the. thats the Neuspeed style one. just a generic version of it. its suppose to have another hole so you can drill the stock bracket, and use a bolt to secure the adapter to the shifter. and yeah the neuspeed one is a perfect fit.
the neuspeed one is probably the better of the adapters. its more expensive which makes it not worth it.. but the OBX replica is a better knock off, since its version is just like Neuspeed's, and it includes the drill bit just like neuspeed too.
the other one posted is the DC style one.. the DC style one is held on via a hex screw.. which these type of adapters have problem where the hex screw falls off from vibration (hence neuspeed's requires drilling). but its definitely an easier install.. again, no point buying the brand name DC one when the generic ones are similiar and cost 50%+ cheaper.
if anyone's interested I got the DC style one for sale.. its semi-new (took it out to take pics for article).
for the price of these things though, u cant complain much. (I mean back then, I bought the Neuspeed for like $90 bucks?)
the Comptech SS is coming out soon, its also an adapter but its two piece adapter, supposely shortens the left to right shifting too.. its meant for the RSX but should fit our shifter assembly. I'll post about it if I remember later on. heh.
Old Oct 8, 2004
gaugeof12's Avatar
Before I get mine & put it in, do you think that putting something like loctite on the threads of the hex screw would help keep it in place?
Old Oct 8, 2004
CapYoda's Avatar
Escaped Convict
yeah that'll definitely help.
although er.. are locktite perm? I forgot after you apply it.. if it can be removed easily.
you can just apply a good strong tape over the screw so it wont be moving out via vibration.. its a solution u might need to apply again and again overtime but it should make it a bit more secure.
remember while you're installing the shifter, to apply lube thru out all moving parts, will definitely make shifting smoother.
Old Oct 9, 2004
suthrninca's Avatar
Looks like it will work, but you may have to dremel it a little. The problem for me was the weld of the cable mount being in the way. It's easier to grind the adapter ( cause it aluminum). Good luck.
Jul 12, 2015 11:54 AM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
ballmich
Jul 9, 2015 11:59 AM
fvckbg
Jul 7, 2015 07:08 PM
