cheap short shift adapter
Not a perfect fit. It's binding on the weld of the oem cable mount. That's an easy fix though, I'll hit it with the dremel in the morning. I was able to hold it all together and shift between 3 and 4 while holding a measuring tape. Original shift distance was 5" and with adapter it looks like it's gonna be 3". I think that's a 40% reduction. Any thoughts about cutting an inch or two from the shifter itself (between **** threads and bend in shifter shaft)?
Got it installed. Works good. Only bad thing about it is that there are no set scews or other means of fastening it to the shifter besides the cable linkage pin. But it's a pretty good fit regardless. I also cut an 1.5" out of the top part of the shifter and had my friend weld it back together. Now the **** sits nice n low and shifts are firm.
I DID
Sounds like you like everything. I ordered one just a few minutes before I saw this thread. What do you think of the quality of this one:
I hope it fits well. Sounds like I spent a dolllar or 2 more than you, 19.95 + 5.50 shipping. But atleast this one has a set screw, infact i think its identical to the arospeed one just with a logo stamped on.
Escaped Convict
the neuspeed one is probably the better of the adapters. its more expensive which makes it not worth it.. but the OBX replica is a better knock off, since its version is just like Neuspeed's, and it includes the drill bit just like neuspeed too.
the other one posted is the DC style one.. the DC style one is held on via a hex screw.. which these type of adapters have problem where the hex screw falls off from vibration (hence neuspeed's requires drilling). but its definitely an easier install.. again, no point buying the brand name DC one when the generic ones are similiar and cost 50%+ cheaper.
if anyone's interested I got the DC style one for sale.. its semi-new (took it out to take pics for article).
for the price of these things though, u cant complain much. (I mean back then, I bought the Neuspeed for like $90 bucks?)
the Comptech SS is coming out soon, its also an adapter but its two piece adapter, supposely shortens the left to right shifting too.. its meant for the RSX but should fit our shifter assembly. I'll post about it if I remember later on. heh.
Escaped Convict
yeah that'll definitely help.
although er.. are locktite perm? I forgot after you apply it.. if it can be removed easily.
you can just apply a good strong tape over the screw so it wont be moving out via vibration.. its a solution u might need to apply again and again overtime but it should make it a bit more secure.
remember while you're installing the shifter, to apply lube thru out all moving parts, will definitely make shifting smoother.
Jul 12, 2015 11:54 AM
ballmich
Jul 9, 2015 11:59 AM
fvckbg
Jul 7, 2015 07:08 PM
