"Bass Boost @ 40Hz"
Old Oct 5, 2004
IronFist's Avatar
"Bass Boost @ 40Hz"
When it says that, and you have a **** to adjust the dB, that is only adding increased volume at 40Hz, right? So if a signal comes through at like 60 or 80Hz it won't get boosted, correct?
Old Oct 5, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
False, it all depends on the slope of the boost. But the boost will be focussed at 40Hz.
On the Pioneer this is what is referred to as the Q I believe. There are Wide and Narrow settings, etc.
Wide might boost like this:
20Hz - 2db
30Hz - 3db
40Hz - 4db
50Hz - 3db
60Hz - 2db
70Hz - 1db
Narrow might look like this:
30Hz - 1.5 db
40Hz - 4.0 db
50Hz - 1.5 db
This is similar for crossovers. They are all rated at how sharply they roll off and cut off the freqs. They commonly will be be 6db, 12db, 18db, 24db, etc ....
Old Oct 5, 2004
IronFist's Avatar
I see. So those db's that are listed for each freq. in your example, those stay relative then, right?
So,
30Hz - 1.5 db
40Hz - 4.0 db
50Hz - 1.5 db
with more boost might look like
30Hz - 8
40Hz - 18
50Hz - 8
Why did they decide to make the boost at 40Hz? And how much do you guys turn yours up? I find that it doesn't sound very good turned up. My lows are already loud enough.
Old Oct 5, 2004
Regularjoe's Avatar
I don't use any of that crap. Good speakers shouldn't need it.
No:
Bass
Treble
Bass Boost
Loud
etc ....
Old Oct 5, 2004
IronFist's Avatar
I use my EQ but not bass boost on the amp.
Old Oct 5, 2004
Regularjoe's Avatar
What EQ, I thought you had a stock deck?
Old Oct 5, 2004
IronFist's Avatar
"Bass" and "treble"
Old Oct 5, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
No:
Bass
Treble
Bass Boost
Loud
etc ....
Thats not true at all...your speakers could have a perfectly flat response on an RTA but if you like treble in your music then you can bost the high frequencies with an EQ to your liking, not wether or not your speakers are "good and dont need it."
Remember, everyone has different ears!
Old Oct 5, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
You could look at it like your both right. Good speakers dont' NEED that stuff to have great response but it CAN BE USED to customize the sound to your ears.
I've got a friend who had his ears boxed by some punk kid when he was 13. He can't hear anything above 3khz. Everytime I get in his car I'm like, ahhhhhhhhhh please bump those tweets down!
Old Oct 5, 2004
Mystic3030's Avatar
Great response and good sound are two different things. Response would be measured by equipment, it doesnt mean its always gonna sound good. My friend has Focal components in his 3.2 TL, technically they have a better response, but I think my quarts sound better.
bowie
Jan 21, 2018 09:29 PM
C-Hamm
Sep 28, 2015 10:31 PM
Michelle2006
Sep 19, 2015 06:09 AM
99BoostedSi
Sep 7, 2015 04:49 PM
Deeup511
Aug 30, 2015 04:48 AM
