What "W" really means in Oil Ratings?
Old Oct 2, 2004
streetglower's Avatar
How many people have thought that the "W" in the oil ratings ( Like 10W-30 or 5W-20) meant Weight?
Well I did, but it doesnt mean weight? It means Winter. Now dont get on here and tell me I am wrong or full of **** because I learned this at school. I am in automotive school.
Just thought I would tell people this who thought it meant weight. Just some useful knowledge to people. If you already knew it, then thats cool.
Old Oct 2, 2004
jttegx's Avatar
OMNES AD UNUM
it can relate. when the oil is cold at certain tempertures, it thickens thus making the oil heavier.
ive always thought of it as "weight" here, and i figured that out by ppl off this forum too. cause i dont know my oil very well
Old Oct 2, 2004
there is alot I have learned at this school, I encourage any one to go to automotive school, I have learned so much **** in the 2 weeks I have been there so far, and I am only on the basic engine stuff so far.
Old Oct 2, 2004
cambo's Avatar
I wish I was asian
If i remember correctly, the W means winter because it was formulated to be okay to run during the winter or extremely cold weather.
Old Oct 2, 2004
pretty much, the first number with the w means the viscosity rating during cold weather, and the last number is the hot weather viscosity rating.
Old Oct 2, 2004
ferio's Avatar
ferio is an unknown quantity at this point
what school do you go to? thanks for the info!
Old Oct 2, 2004
UTI (Universal Technical Institute). It is expensive, but worth it so far IMO. I am in the basic engine course right now. We have a new course every 3 weeks.
Old Oct 2, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
Old Oct 2, 2004
sw388integra's Avatar
knew it...but good to spread da word...
Old Oct 2, 2004
player's Avatar
Awsom information, that makes alot of sence. Makes me understand what kind of oil i am using.
thanks man, good post
Old Oct 2, 2004
zachgeyer's Avatar
Wwwwwwwwwwwwwwwwwwww
Old Oct 2, 2004
you make the absolute most asinine posts ever.. I don't think i've ever seen one of your posts that has something to do with anything, or has any validity at all. that's freaking awesome!
Old Oct 2, 2004
so who thinks this post should be stickied? I sure as hell do. I wish I could tell you all more, but you have to pay to learn
But yea, I thought I would just let everyone know that.
Lets see what else can I tell you about oil. Well if you dont know, dont ever listen to people who say you can change your oil at 7500 miles, change it every 3k if you do alot of stop and go driving and about 4-4500k if you do alot of freeway driving, reason being is that you would think oil keeps doing its job but after a while it justs gets dirty, that is not true, well in a since it is, but after a certain period of time, the additives in oil dissapear, or basically go away which turn your oil into base oil, which is not good for your engine. Basically it will erode your bearings in your crankshaft, screw up your oil pump, and also cause premeture wear. And in some cases, your engine will lock up. The whole purpose of changing your oil often is because you want to have the additives in there.
Also if you have alot of miles on your engine and you want to clean it, use diesel motor oil. It sounds stupid, but diesel motor oil will clean your engine out really good. use it about 7 oil changes and change it every 2k miles. then switch back to your regular motor oil. I thought it was stupid at first, but it helps to clean your engine.
Old Oct 2, 2004
xgimmick's Avatar
xgimmick will become famous soon enoughxgimmick will become famous soon enough
"what do you think lance ? 40 weight ? 50 weight ?" "40 weight sounds nice"
iono why that post made me think of that
Old Oct 2, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
you obviously havent seen bobistheoilguy.com.. i dont think this thread should be a sticky, but a link to the site i mentioned should.
first, oil can go well over 3k. ive got mobil 1 in my engine right now and its got about 7k in it right now.
if you look at this link, you'll see used oil analysis on an accord used for well over 3000 miles, showing great numbers, and the TBN is still good, indicating the oil still has plenty of life left in it. honda engines are pretty easy on motor oil and unless you really severly beat on your car, 3k is not necessary.
and about diesel oil, yes, it does have more cleaning agents, but if you find yourself burning oil you shouldnt use it since it can damage your cat. if you do decide to use diesel oil, id try to find rotella 10w-30 insted of the popular 15w-40. or you could just try auto-rx which has worked well for many.
every engine is different, every oil is different. for example, turbo cars are very hard on oil, but cars like our civics are very easy on oil.. so there is no one interval.. there are a lot of factors to consider
Old Oct 3, 2004
informative post thank you
maybe you should read the books there.. chris j/k buddy
Old Oct 3, 2004
TurboDieselDrew's Avatar
TurboDieselDrew is an unknown quantity at this point
Great post. http://www.bobistheoilguy.com is a great resource and Auto-Rx is an even better product.
For the real truth about your car and the oil in it, send in a sample to Blackstone labs. http://www.blackstone-labs.com/
Old Oct 3, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
i knew that steetglower and i am almost done with my automotive classes. learned it last year in my first semester. thats y i use 5w50 in my d17a1
Old Oct 3, 2004
modoman's Avatar
i used to work in a shop changin oil and bustin tires all day (ugh)
i changed this one guys oil in a s-10 once... you would not believe how lumpy it was... looked like cocoa puffs in chocolate syrup.
synthetics can last a whole lot longer than conventional oil too, and mobil one is the best oil ever made! woo
Old Oct 3, 2004
xam's Avatar
xam
not really i rather have penzoil
Old Oct 22, 2004
Yakkolio's Avatar
Yakkolio is an unknown quantity at this point
winter!
Old Oct 22, 2004
RallyeRed2k2's Avatar
RallyeRed2k2 is an unknown quantity at this point
i go to UTI also but in glendale heights, illinois. Im in advanced electronics phase 22
Old Oct 22, 2004
I am in 28 right now.
Old Oct 22, 2004
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
actually it is commonly refered to as weight and winter. it just refers to how the thick or the 'weight' of the oil will be while cold or warmed up. polymers are added to the base oil (5W, 10W, 20W...) that stop the oil from thinning too much when under operating temperatures. when the oil is cold, the polymers are all coiled up and flow as thin as the normal rating (for me it would be 5W), but when the oil is up to temperature, the polymers unwind and stretch into chains that stop the oil from thinning too much. so for me, i have oil that when it is cold is at a 5 weight/winter viscosity, but it will never get as thin as a 20 weight/winter would when heated. (5W-20). lets thank the oil gods for creating multi-viscosity oils.
Old Oct 22, 2004
CivicsRdBest's Avatar
I learned the W thing from a car show (I forget which one right now but I'm guessing motorweek) and I still think the rest of this was an interesting read...
RIPSAW
Nov 6, 2015 04:36 AM
BootyDo
Jul 7, 2015 06:06 AM
ZILLA
Jul 5, 2015 05:24 PM
97-DX-Lover
Jun 14, 2015 06:07 PM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
