need help- wiring please- will give points if you can help me
Super Member
okay, dont ask me why, but i need your help. There is a cluster of wires, on the passenger side (2001 EX coupe) that runs just inside the wheel well, just inside the engin compartement. If you follow the tie-rod, where it enters into the engine compartement, its right there. It is a cluster of about 20 wires. Anyways, I need to now what the green/black wire goes to. I will give some serious points to someone who can help me out!!!!!
If you mean litegreen/black, that's the powersteering pressure switch. It runs from the steeringrack high pressure hose to the ecu conector E pin 16.
The LT Grn/Blk wire goes to the PSPSW.
THe regular Green and black wire goes to the washer/wiper moter and switch, and then to a 20amp fuse.
Test the wire with a test light for power. Then pull the wiper fuse and see if power goes out and you'll know if thats your wire.
Jason
Jason
Originally Posted by fuledya
So if it was disconnected then no power steering?
At least that's the only green/blk wire that runs back through the firewall where you indicated.
It does help to have a manual.
usajags84
15
Aug 19, 2015 03:12 AM
tkcne
Apr 18, 2015 02:33 AM
BREADFAN
Apr 15, 2015 08:58 AM
