How many running the relay for SF fuel system?
Old Sep 26, 2004
Ahtasham's Avatar
Ahtasham is an unknown quantity at this point
Hi guys. Since I am really close to installing the SF kit (just waiting on the last box to get released from the customs ) I am making sure that I have got everything covered.
For now I was wondering on the fuel system, thinking if I should:
1) Use the relay that would turn on the pump upon boost?
2) Use an on/off switch from inside the car instead of the relay?
3) Hook the pump directly so it will stay on all the time?
What do you guys suggest and what setup do you have?
Thankx!
Old Sep 26, 2004
Civic Type S's Avatar
Civic Type S is an unknown quantity at this point
even though I have had the relay on my turbo kit for a year, I want to know the same ?, my pump lately, when my car idles for about 1 minute the pump starts to get really loud, gow can this be fixed, it sounds horrible
Old Sep 26, 2004
abmerop18's Avatar
Jam out with your clam out.
i heard the SF fuel system is always loud. thats normal i think
Old Sep 26, 2004
Jeff's Avatar
Jeff is an unknown quantity at this point
Why not tap into the main relay wire, that way when you prine the system(turning the car on)the fuel pump turns on the same time as the stock pump.
Old Sep 26, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Buy a NOS pressure sensor and set it at 1psi of vacume. That way at idle and off boost the pump does not get worn out pumping every second the car is on. If you take a long trip and on cruise control wh have the damn pump just buzzing behind you glove box. Open your glove box next time you are driving. You can here it clearly.
Old Sep 26, 2004
civic01vtec's Avatar
Well, i am on my 3rd pump right now and i was on my 2nd relay.
This past pump i blew, i went out and bought a toggle switch and a 30 amp in-line fuse. This way, if i am warming my car up or at a long red light i can shut my pump off.
Old Sep 27, 2004
dragoon's Avatar
i'm using the relay, just hope it and the pump last another few months before i go return style
Old Sep 27, 2004
Ahtasham's Avatar
The NOS pressure sensor and the relay seems to serve the same function though ..... or is it not? Probably the NOS sensor might work better ..... I really dont know
The relay is there to turn on the pump when it senses boost, right? How many of you have had actual problems with the relay so far?
Old Sep 27, 2004
gotti's Avatar
^lol, guns knows his ****. If he says it'll work, it'd take his word for it.
Old Sep 27, 2004
that is correct............but i did have one relay take a **** on me when i was boosting 9psi. Thank god i had a spare.
Old Sep 27, 2004
guns's Avatar
Skyline R33
can some one explain the relay. I dont have one. I have a NOS pressure switch that turns on at a set psi/vacume. How does the relay know there is boost. I have heard of hooking methanol to the vtec light. When the car hits vtec it sprays. But our cars engage too low for that. But it would be a good switch for the pump.
Just ideas and questions. I am learning as I go. My next project is learning how to Pnp a head. I bought mine and think could have done just as good or better.
Old Sep 27, 2004
the relay does not sense boost. The relay just turns the pump on when the ignition is turned over. The fmu senses boost and will adjust for the increased fuel pressure.
If you notice on the SF fuel system, there is a aluminum tube that runs from the "In" to the "Out".........this is a bypass. The bypass will allow fuel to go to the rail when not in boost and also if the booster pump breaks.
As far as running methanol when vtec is engaged is completely unnecessary. The stock ECU is programmed to supply the proper amount of fuel when vtec is engaged. Besides, any obd II car will supply enough fuel for a 35 shot of n2o.
As far as porting your head, it really isn't that hard. You just need the proper tools and some knowledge of what you are doing.
Here is a link for some info.
http://racingknowledge.org/topic.asp?TOPIC_ID=1497
Old Sep 27, 2004
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
I like that idea.. where could you pick one up? does it have to be a NOS sensor, or would a place like AutoZone have a pressure sensor that could be set to sense vacuum?
also, I think I recall reading that having the pump turn on and off frequently could wear it out faster.. is this true?
Old Sep 27, 2004
guns's Avatar
Skyline R33
Cool thanks. A friend is going to show me how. He has an air compressor and the tools. I just need to be the supplies to do the work. I have been doing research. What do you think of Spilit-second.com that is the fuel system the catalyst claims to have made 300whp on stock internals with? Keep the info and opinions coming.
Old Sep 28, 2004
vector4's Avatar
vector4 is an unknown quantity at this point
on using a pressure sensor to turn the pump on only when its needed. how fast does that pump come up to full pressure. say if you drop the hammer and spool up 7psi the pump needs to come up with 70psi of fuel pressure right quick. I assume it runs up pretty fast but i wonder if there is any delay at all.
Old Sep 28, 2004
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
^ is my friend who helps with my problems/needs with my car
he knows a lil' something something...btw, he's running 13.0 in his SRT4 with just $1500 MAX in mods...I know there is a thread on this (SRT4's) in the track/speed/strip section...
Old Sep 28, 2004
Ahtasham's Avatar
Wait a sec, you got me all confused again. If the relay only turns on the fuel pump when you turn on the car, this would mean the pump stays on all the time whether or not the car is under boost? am I right? This would mean that you would hear the humming kinda sound from the pump all the time ???
Old Sep 28, 2004
ding ding ding....we have a winner ....tell him what he has won bob
a ice cold
Old Sep 29, 2004
Ahtasham's Avatar
a ice cold
ahhhh, I thought the relay would turn on the pump ONLY under boost. Guess I was wrong. So why not have an on/off switch instead ??? At least that way the annoying sound of the pump wont be there when driving in traffic where no boost is required ..... what do you think?
Old Sep 29, 2004
ding ding ding............we have a winner again.......damn, u are good at this game
I ran the power wire from the left red screw in the fuse box and installed a toggle switch near my cig lighter. I also installed a 30 amp in-line fuse too.
If i am letting my car warm up/cool down or am sitting in traffic, i just shut the damn thing off.
Old Sep 30, 2004
Ahtasham's Avatar
Wonder if there is any downside to it (turing the pump on and off). A friend of mine has done this to his boosted 6th gen and when he turns the pump off the car acts as if its getting less fuel but then in a few mins it gets back to normal.
CarStuff
Dec 6, 2020 12:52 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
TaiChi
Dec 17, 2001 09:09 PM
NukeSilo
Nov 20, 2001 05:17 PM
