MSD for timing control?
Old Sep 16, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
Here is a cut and paste from their website:
MSD DIS-2, PN 6211 (2 Channel Ignition)
Maximize your vehicle’s distributorless ignition system (DIS) with MSD’s powerful new ignition controls; the MSD DIS-2 and DIS-4. These Ignition Controls feature Multi-Channel capability, and can deliver up to 480 volts to the primary side of most DIS type dual output coils. With its two channels, the MSD Digital DIS-2 is designed for use on all 4-cylinder applications using 2 coils, while the DIS-4 can be used on all 6 and 8-cylinder engines with three or four coils.
Programmable Timing Control
Precise timing control is essential to producing maximum engine power. With the addition of nitrous, turbos or supercharger systems, timing becomes even more critical. To get the most out of your engine, the ignition must be able to compensate for these extreme changes in cylinder pressure throughout the engine’s entire rpm range. During low speed operation, the MSD DIS Ignitions use the factory ignition to control basic timing functions. Once maximum timing is achieved, the DIS-2 and DIS-4 can be programmed to retard the timing at a specific rate and rpm point to prevent engine damage due to detonation caused by excessive timing.
Old Sep 16, 2004
abmerop18's Avatar
Jam out with your clam out.
dont think it can work with the direct coil injection of the 7thgen.
someone correct me if i am wrong
Old Sep 16, 2004
guns's Avatar
Skyline R33
The website says it is for distributorless engines. So that means coil packs right? Direct coils do not use a distrubutor.
MSD DIS-4 is MSD ignition for distributorless engines 4 coils.
Or am I way off?
Old Sep 16, 2004
teampointless's Avatar
Ultimate Member
i'll check into in later on tonight... they have one at the Autozone around the corner from me.. PM me about it...
Old Sep 16, 2004
lid6662's Avatar
lid6662 is an unknown quantity at this point
Hope It works The more stuff out the bettter
Old Sep 16, 2004
frickinspic's Avatar
frickinspic has a little shameless behaviour in the past
word some one hit me up when u get the news if it works with our cars...
Old Sep 16, 2004
riceburnrex's Avatar
First to spool
riceburnrex has disabled reputation
Quote from MSD's site:
"DIS-4 can be used on all 6 and 8-cylinder engines with three or four coils."
MSD systems are designed mostly to be used with cars that use one coil for two cylinders. The DIS-2 is setup to work with 4 cylinders, but only 4 cylinders that use two coil packs. They do not have an igntion designed to work with Coil on Plug, which is totally different from coil pack setups that use one coil with multiple cylinders. I called MSD about this two years ago, and they said the DIS-2 or DIS-4 would not work on our car.
The AEM CDI works with our cars, but does not allow you to change timing. It only provides multiple and better sparks.
Old Sep 17, 2004
guns's Avatar
Skyline R33
i wonder of the dis-4 could be modified to work. it works for 4 coils right? a couple of places says they wanted to try it out.
Old Sep 17, 2004
Ultimate Member
it's confirmer that the DIS-2 will not work on our cars, but I'm being told that the DIS-4 could be modified to work... i say we check it out ML...
Old Sep 17, 2004
civic01vtec's Avatar
i was actually wondering that myself. Coil packs and direct coil on ignition are 2 different things. Thanx for clearing things up bro
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
bryden13
May 18, 2015 12:22 PM
locozoko
Nov 8, 2001 06:33 PM
