Need Help with Caliper Sliding Pins
Old Sep 12, 2004
pinkytube's Avatar
pinkytube is an unknown quantity at this point
My 2002 has two different "caliper slide pins"; These are the actual bolts which the caliper bolts on to. They slide within the pad bracket. I removed these to replace all the grease, and to clean them up, and replace the little grease/dust boots which were a little torn, and now I forgot which one goes where. There is one perfectly round one, and one with 5 or six sides like a hex bolt or something. there has to be a reason they were made different, and I need to know if the round one goes towards the front of the car, or towards the rear of the car? Any ideas?
Thanks
Old Sep 12, 2004
streetglower's Avatar
there should only be one pin per caliper. The bottom part of the caliper just unbolts, then you can swing the caliper up to change the pads. then the caliper slides out of the bracket from the top if you are doing other work. Other then that, I am not sure what you are asking.
Old Sep 13, 2004
pinkytube's Avatar
There are two pins which slide within the caliper bracket. When you remove the caliper completely from the car, the two sliders can be removed from the bracket also. They have black dust boots on them, and grease inside. One is perfectly round, and the other is kind of a hex shaped pin.
Old Sep 13, 2004
show me a pic man, because I only have one sliding pin per side. When you unbolt the caliper on the bottom nut from the bracket, you can flip it upwards, then you can pull the top part out of the bracket. that is the sliding pin. Maybe we are thinking of 2 different things. Pics would be great though.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Junquito89
Sep 27, 2015 10:22 PM
Bruce2
Sep 27, 2015 08:45 PM
