Sponsored by:
Sponsored by: CARiD
Obx Header dx/lx
Old Sep 8, 2004
civiclx4dr's Avatar
civiclx4dr has a little shameless behaviour in the past
Obx Header dx/lx
I ordered the stainless steel header from obx, and was wondering if anyone knows if it is good and will not harm my car. Its has the plus for the sensors, so will my engine light stay off.
Old Sep 8, 2004
civicstyle82's Avatar
civicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to all
Moved to Other Products and Parts
Old Sep 8, 2004
streetglower's Avatar
you need to start posting your questions in the right forums. And start searching, this has been covered thousands of times before.
It is a waist of money. Send it back and buy something else. You will only get maybe 1-3 HP from it. No, it wont harm your car.
Old Sep 8, 2004
HELP_ME's Avatar
HELP_ME is an unknown quantity at this point
well... I have it.. and the engine check light will be on, since you remove the stock header, so what I did was using a O2 simulator... then the light goes off.
Still, you wouldn't notice any difference... i will say~...
Old Sep 9, 2004
civiclx4dr's Avatar
Do You Need A 02 Sensor For The Dx Lx Obx Model Header? It Has To Plugs On It And Is Different Than The Ex Model Header. For The Dx Lx Model Header, Will My Engine Light Stay Off? If I Need A 02 Simulator Can Someone Tell Me When I Can Get One. Thank You
Old Sep 9, 2004
civiclx4dr's Avatar
can anyone answer my question?
Old Sep 9, 2004
HELP_ME's Avatar
yes.. you NEED a O2 sim, doesnt matter LX or EX... buy one and install it when you install the header...
Old Sep 9, 2004
civiclx4dr's Avatar
where do I buy it
Old Sep 9, 2004
HELP_ME's Avatar
http://www.casperselectronics.com/Me...ory_Code=honda
or
http://www.bigjoshracing.com/store/shop/index.html
Old Sep 9, 2004
civiclx4dr's Avatar
the the mil eleiminator from the other webstie the same? it costs 12 bucks and the other one is 75
Old Sep 9, 2004
HELP_ME's Avatar
they do the same thing... but some people said the cheap one doesnt work, and it requires cutting and wiring...
The casper one just simply plug it in, and works.
I have the one from bigjoshracing and it works fine with me...
Old Sep 9, 2004
518's Avatar
518
518 is on a distinguished road
I have an LX and running the EX OBX Header mated to EX RandomTech high-flow cat. No CEL, no cutting and or splicing of O2 wires to extend it, no need for O2 sim.
4K miles, NO CEL.
Old Sep 9, 2004
civiclx4dr's Avatar
I got the obx dx lx model, is the 02 simulator just a plug in to the stock wire or will there have to be splicing?
Old Sep 9, 2004
Michalo187's Avatar
Abortion Survivor
I have obx headers and yeah they do help but u loose low end yes your check engine light will be on and no i havent fixed it yet if you get one of those simulators let me know how it works
Old Sep 9, 2004
HELP_ME's Avatar
I have big Josh's O2 sim, works great with me~
Old Sep 14, 2004
civiclx4dr's Avatar
i just got the obx header for the civic 03 lx 1.7. I didnt install the 02 sensor for it yet and my engine light isnt on.......is that good that ots not on or do i still need to put the o2 sim?
thanks
Old Sep 14, 2004
civiclx4dr's Avatar
can ne1 answer?
Old Sep 14, 2004
zachgeyer's Avatar
it wont
Old Sep 14, 2004
civiclx4dr's Avatar
it wont what?
Old Sep 15, 2004
jttegx's Avatar
OMNES AD UNUM
with the car throwing out lights, luck plays a role too. unforunately, im one of those bad luck ppl and got my malfunction lamp on. i have both o2 sensors and seems like my malfunction indicator lamp is gonna be on forever unless i install a sim/elim.
dont be too suprised when the light comes on after a day or 2.. thats what happened to me.. i tried disconnecting the battery and the o2 sensor fuse for 15min, still no luck. so im just running my car with that dam light on, (keep in mind, its not actually harming the engine, its just their to annoy you) so your getting the actual gas mileage your suppose to get, etc etc.
^btw, you wont be able to get zachgeyer to post a sentence or 2, all of his post at like 2-5 words at most.
Old Sep 15, 2004
jcivic01's Avatar
jcivic01 is an unknown quantity at this point
i had the obx header on my 01 lx with the o2 simulator. the cel didnt come on at first, but after 5 or 10 start-ups it lit. the crappy design of the header made it a bad choice. i was constantly fixing exhaust leaks. i took it off after two months due to this problem as well as the nasty rice sound it gave to my exhaust. the cel stayed on for quite a while, but it eventually went off. learn from my mistakes and dont run the header. its a lot of money for tons of problems and the terrible sound of rice. even though the stock manifold is more restrictive, there isnt a noticeable difference in power vs. the header.
Old Sep 15, 2004
civiclx4dr's Avatar
i see. what other problems... will it cause mechanical? if so i will take it off asap.
thnx
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
ThatGuy913
Nov 9, 2015 06:31 AM
jdh022764
18
Nov 3, 2015 06:44 AM
anubis62
Sep 27, 2015 12:56 AM
