How do you do it???
Old Sep 8, 2004
Civic6-Speed's Avatar
Civic6-Speed can only hope to improve
How do you do it???
I dont know how you guys keep your body kits from getting wrecked when your car is low. My car has a 2 inch drop and its kitted and I have tried everything to avoid cracking it when i pull out of a steep driveway but nothing seems to work. So how do you guys keep it from hitting? I guess im doing something wrong.
Old Sep 8, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
u drive in horrible roads and one mistake u make is also pulling into steep driveways. i just park on the side of the road...
Old Sep 8, 2004
Mr.Modify's Avatar
i normally go over anything that has a bump or incline at an angle...and the worse i get is a scarpe on the mid pipe......to where i can actually feel it being pushed up into the car.
Old Sep 8, 2004
eklipz's Avatar
to avoid cracking dont buy fiberglass. And do as the above post says
Old Sep 8, 2004
solo_rider's Avatar
solo_rider is an unknown quantity at this point
yeah i jus got finish redoing my body kit for the 3rd timr and i've only had it for about 4 months
Old Sep 8, 2004
rijowysock's Avatar
ThE FaMiLy SeDaN
the 30/60 rule... 30 degree and 60 degree let the tire hit the incline b4 the kit and then the kit will be raised....go next to the incline and turn tires toward it it'l life the car b4 the kit has a chance.
my front is 2" off the ground and sides are 7/8" off the ground and i never scrape even speed bumps u just gotta do it right(i use my rule modifyied, 20/70 degree rule cause im TOO low
Old Sep 8, 2004
dawn01civ's Avatar
Eddie is so hot. *sigh* I want him......BAD
dawn01civ has a brilliant futuredawn01civ has a brilliant futuredawn01civ has a brilliant futuredawn01civ has a brilliant futuredawn01civ has a brilliant futuredawn01civ has a brilliant futuredawn01civ has a brilliant futuredawn01civ has a brilliant futuredawn01civ has a brilliant futuredawn01civ has a brilliant futuredawn01civ has a brilliant future
an ex had a slammed accord and every time there was a speed bump or inclined driveway he just went slow and at an angle.. most of the time it worked.. hehe
Old Sep 8, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Its all about apoarching the obstacle at an angle.
Old Sep 8, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
use the 20/70 rule.. it actually works.. Just hit it so the tire hits first and that will raise the body of the car up enough to get it up the steep incline..
and speed bumps don't really affect me unless i'm plowing over them.. (which would be dumb to do anyways)
Old Sep 8, 2004
streetglower's Avatar
my car is only dropped about 1.5 inches, but I still scrape everywhere with my exhaust cause it only has 6 inches on clearance. I just go also at angles and it works for me.
Old Sep 8, 2004
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
my 88 hatch skimms speed bumps as it is good thing i dont mess with fiber glass
Old Sep 8, 2004
Team Hi Voltage's Avatar
Team Hi Voltage is an unknown quantity at this point
Old Sep 8, 2004
incubus7d's Avatar
I Wanna Die Like God on the Cover of Time!
incubus7d is an unknown quantity at this point
Hey whats are those things (maybe this will help) i see all the time on slammed car with kits, on the front of the kits the got 2 looks like wire holding the bottom of the bumper up, like you go over a bump if you hit it protects it and pulls it up, is this correct, does anyone no what i mean!! Would that work. Im not fimiliar with them i just saw some people with them
Old Sep 8, 2004
R1Style's Avatar
Yeah... don't drive straight at an incline. Always hit it one wheel at a time.
Old Sep 8, 2004
DexMan's Avatar
DexMan is an unknown quantity at this point
That is the other thing with kit, there are a lot of maintence(sp?) after you have it on. When I first had my kit, avoid speed bumps, learn how to angle your car going up and down. The most look out for objects in the middle of the road. I dont know if it is really a different but when I got 18's it didnt scaped as much.
Old Sep 8, 2004
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
I would guess that you are talking about a front diffuser (see pic below).
If that is what you were refering to its actually for aeordynamics & would cause the front to be lower than before (thus no help for protection).
Old Sep 8, 2004
Keet's Avatar
Keet will become famous soon enough
Get air ride or hydrolics :P
Old Sep 9, 2004
02sleeper's Avatar
Boosted Auto Sedan Project In Progress
02sleeper is an unknown quantity at this point
its hard but you learn
