Serious performance air filters
Check it out. They're better than K&N in every way and claim to flow the most air. They even have new cone filters!
http://www.sbfilters.com/products/index.htm
http://www.intenseperformance.com/pr...e_filters.html
1. Deeper and more numerous pleats
2. Can't see light through it like you can with K&N (better media)
3. velocity stack design (already proven by the apexi power intake)
4. polyurethane rubber mounts
5. flow bench tested to provide enough air for 600hp engine.
Only con is it could be louder than filters with a closed front like standard AEM and K&N, both of which result in higher turbulence anyway (this is bad initially, because turbulence reduces air velocity through the intake).
And they even have add-on cold air system that you can connect to the stock airbox with tubing and filter.
Well you would just get a replacement filter for your existing intake. They have all sorts of sizes. Yeah I checked and they don't offer the actual intake for our cars. The filter still sounds really good.
Civic2002lx
Oct 7, 2015 09:17 AM
MegaBassX
Jun 11, 2015 08:52 AM
