I may have overlooked it...but..E-Manage ignition and injector wiring? Someone help!!
Old Aug 29, 2004
Hwoody77's Avatar
Hwoody77 can only hope to improve
Hey everyone I recieved my e-Manage today, and I figured out the wiring for the main harness...but not for the other two...
Is the injector harness - Injector 1, INjector 2, Injector 3, injector 4, and injector ground?
How about the ignition harness? Thanks in advance!
Old Aug 29, 2004
opto_isolator's Avatar
Originally Posted by Hwoody77
Please anyone? Opto? Dezod?
If you search you will find your answers...
Old Aug 29, 2004
dezod's Avatar
7thgen Power Maker
What exactly do u need to know?
Old Aug 29, 2004
Hwoody77's Avatar
I searched and found nothing...
I bought an e-Manage with injector and ignition harness, and I don't know what to hook up on the ignition and injector harness to our ECU....
Old Aug 29, 2004
There are numerous posts about this. Please read in the the tech section for more information. This thread is redundant if all you are looking for is what to connect the ignition and injector harnesses up to.
Old Aug 29, 2004
Hwoody77's Avatar
No, I read that whole thing...it had how to install the basic harness, but not the ignition and injector harness...
Old Aug 29, 2004
Hwoody77's Avatar
Ok, hear me out...
You have to hook up...
Main Harness
Power
Ground
Map In
Map out
RPM
TPS
I'm not wiring VTEC up BTW..
Ok, now is where I am confused...
For the Injector Harness is
Injector 1
INjector 2
Injector 3
INjector 4
Injector Ground...
Am I missing or adding anything extra here?
And now is where I am really stuck on...Ignition harness...
Is it a total of 8 wires?
Igniton 1 input and output...
Ignition 2 input and output...etc?
Old Aug 29, 2004
Havok2k1's Avatar
Wicked Pissah Admin
http://www.7thgencivic.com/forums/sh...jector+harness
http://www.7thgencivic.com/forums/sh...d.php?t=114042 (not sure if thats the right diagram...)
All i could find after looking for 45 minutes....
Old Aug 30, 2004
Ok, hear me out...
Main Harness
Power
Ground
Map In
Map out
RPM
TPS
Injector 1
INjector 2
Injector 3
INjector 4
Injector Ground...
Yep - all of the wires you mentioned are correct. Yes, there are a total of 8 wires for the ignition, 4 for injectors.....
Old Aug 30, 2004
Hwoody77's Avatar
What about the injector ground wire...should I just ground that anywhere?
Old Aug 30, 2004
I believe there is an injector ground....I don't have my manual in front of me at the moment.
Old Aug 31, 2004
dezod's Avatar
7thgen Power Maker
PM me if you still need help.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
pincookie1
May 4, 2015 12:22 PM
green01civic
Apr 29, 2015 01:36 PM
BREADFAN
Apr 15, 2015 08:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
