I may have overlooked it...but..E-Manage ignition and injector wiring? Someone help!!
Hey everyone I recieved my e-Manage today, and I figured out the wiring for the main harness...but not for the other two...
Is the injector harness - Injector 1, INjector 2, Injector 3, injector 4, and injector ground?
How about the ignition harness? Thanks in advance!
7thgen Power Maker
I searched and found nothing...
I bought an e-Manage with injector and ignition harness, and I don't know what to hook up on the ignition and injector harness to our ECU....
Ok, hear me out...
You have to hook up...
Main Harness
Power
Ground
Map In
Map out
RPM
TPS
I'm not wiring VTEC up BTW..
Ok, now is where I am confused...
For the Injector Harness is
Injector 1
INjector 2
Injector 3
INjector 4
Injector Ground...
Am I missing or adding anything extra here?
And now is where I am really stuck on...Ignition harness...
Is it a total of 8 wires?
Igniton 1 input and output...
Ignition 2 input and output...etc?
Main Harness
Power
Ground
Map In
Map out
RPM
TPS
Injector 1
INjector 2
Injector 3
INjector 4
Injector Ground...
http://www.7thgencivic.com/forums/sh...jector+harness
http://www.7thgencivic.com/forums/sh...d.php?t=114042 (not sure if thats the right diagram...)
All i could find after looking for 45 minutes....
Ok, hear me out...
Main Harness
Power
Ground
Map In
Map out
RPM
TPS
Injector 1
INjector 2
Injector 3
INjector 4
Injector Ground...
Main Harness
Power
Ground
Map In
Map out
RPM
TPS
Injector 1
INjector 2
Injector 3
INjector 4
Injector Ground...
What about the injector ground wire...should I just ground that anywhere?
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
pincookie1
May 4, 2015 12:22 PM
BREADFAN
Apr 15, 2015 08:58 AM
