Remove Resonator ?
Old Aug 16, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Remove Resonator ?
Hi everybody, was thinking of removing the resonator on my 7th Gen and replacing it with just an aluminium flexible pipe similar to those used in air con ducts. The aluminium pipe will connect the airbox which houses the airfilter and the final stock pipe which points to the side of the car body. Anyone done this or has anyone removed the resonator and the last few inches of piping, replacing it with flexible piping altogether ? Would my low end suffer as a result ? What would the gains be as a result of such a mod ? What's would the induction noise level be like?
Old Aug 16, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
Will do nothing for your car except make it loud...if you are strapped on cash, you would be better off getting a K and N air drop in box air filter...stock setup is best for torque...the K and N will give you a little more "umph"...
Old Aug 17, 2004
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
I removed the whole resonator box before I bought my e-bay intake... Filter box and intake feel the same power wise, lose a little low end, gain a little mid/top end. You could run a flex pipe over to the fender, that would probably help it suck some cooler air.. Gains are pretty much negligable on the D series untill you get into major engine/forced induction. Doing intake/exhaust just increases driveability some and makes the car sound better.
Stock filter box makes very deep intake noises at idle and through the lower RPM but no more sound than you're used to a higher RPM. A chunk of aluminim pipe with a cone filter on the end of it provides the best sound IMO.
Old Aug 19, 2004
dean's Avatar
dean is an unknown quantity at this point
maybe u like to check with Jon-Neoursis2..... he did the same setup also....
Old Aug 19, 2004
It makes the car perform horribly, and not just because there's more hot air near the intake. Also sounds VERY loud like a broken exhaust.
cukaracha
Aug 27, 2015 02:02 AM
herbiej
22
Aug 23, 2015 01:02 PM
WaryDriver
Aug 16, 2015 11:22 AM
greenbackz
Jul 30, 2015 12:04 AM
ballmich
Jul 9, 2015 11:59 AM
