Registered User Join Date: Apr 2002 Location: Toronto, ON Posts: 29 Registered User Join Date: Apr 2002 Location: Toronto, ON Posts: 29 What fuse amp rating should I use in this two amp configuration?
Old Aug 14, 2004
klam's Avatar
klam is an unknown quantity at this point
Here is a rather simple question that maybe someone could answer?
I am planning to have a set up as follows:
[Battery]
| (4 awg) x amp fuse?
[Distributor block]-----(10 awg) y amp fuse?-----[Pioneer 2x60W RMS amp]
| (10 awg) 20A fuse
Infinity Basslink (200W RMS)
I'm wondering what amp rating fuses I should use between the battery and distributor block? And what to use between the distributor block and 2x60W RMS amp for door speakers?
Old Aug 14, 2004
MegaHurtz's Avatar
For fuses, use the size recommended by manufacturer. If the amp has fuses on it use that size.
For the front by the battery, add the sizes of all your fuses up and use that size
CarStuff
Dec 6, 2020 12:52 PM
Civic2002lx
Oct 7, 2015 09:17 AM
izdman
May 19, 2015 03:43 PM
smmahan
Apr 15, 2015 08:17 PM
