Idea: using home stereo speakers for our rear speakers?
Old Aug 10, 2004
zen_master's Avatar
Lightbulb Idea: using home stereo speakers for our rear speakers?
hi guys!
i got an idea........i got two home stereo speakers...they're like probably 8 ohm....
do you think they will work if i plug it in into our rear speaker harness??
Old Aug 10, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
they will probably get about 4 watts and blow as soon as you turn it up.
Old Aug 10, 2004
zen_master's Avatar
hmmmmmmmm
the speakers are the one that's gonna blow, right?
however, why? can u explain?
Old Aug 10, 2004
Mystic3030's Avatar
It's gonna take alot more than 4-6 watts to get a speaker going at listenable levels, so the amp is going to try and put out more, and clip, and send a super distorted signal to the speaker causing it to blow.
Old Aug 10, 2004
zen_master's Avatar
ic..........
so, how many watt is it actually the OEM radio sends to the rear speakers?
which amp u'r reffering to? the "amp" inside the OEM radio?
i was thinking to directly plugs the red/black cable from the harness into the stereo speakers......lol
Old Aug 11, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
That is not a good idea, the ohms need to match up and the weather elements will damage the speaker.
Car speakers are designed to withstand extreme heat and cold, where as home speakers will fail under extreme heat and cold conditions.
Old Aug 11, 2004
zen_master's Avatar
^^true true......
curious though, what's the minimal ohm and watt for the car speaker?
Old Aug 11, 2004
Mystic3030's Avatar
Stock speakers are 4ohm. The factory radio sends around 12 watts per channel, so at 8ohm you cut the wattage in half.
And yes, I am referring to the amp inside the factory radio.
Old Aug 12, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
just curious but why are home stereo speakers 8ohms instead of 4ohms?
Old Aug 12, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
cuz its 12v in the car adn 120v in the house
Old Aug 12, 2004
Regularjoe's Avatar
Regularjoe is on a distinguished road
Think of ohms as a measure of how hard it is to move a speaker. The higher the ohms on a speaker, the harder it is to move. Some will argue that a sub w/ a higher ohms will be harder to move, and therefor can be controlled more accurately. This is called damping. So theoretically the more the ohms, the better it can sound.
Also think about the power aspect of it. In either home or the car world the voltage is kept constant (12v or 120v). Given that the only way to make lots of power is to decrease the ohms or increase the current. So in the car world where power is limited, generally most bass amps want reduced ohm loads to get lots of power (like 1 or 2 ohm stable amps). To get to 1 or 2 ohms, it generally requires subs w/ low resistances. This is why some amps pull 60, 80, even 100 amps of current.
Most home amps can run at 8 ohms and won't even get close to taking 5 amps of power. Different kinds of power available, so the approaches to all the equipment id different.
Old Aug 12, 2004
doubledeuce2k2's Avatar
just please drop the idea of using home theater speakers powered by the HU in your car. it won't work right.
Old Aug 14, 2004
LudlamTheory's Avatar
i boogie for the raindrops
it would work absolutely golden if done correctly sir....
none of you could do it correctly is the thing
i've used home theater oriented drivers in my car before, granted it was the raw driver stripped from any enclosure, but lets say he wanted sound, and really liked how speaker "a" sounded altogether, if he were to spoperly install that, flushing it in place, allowing proper power, then yes, he could definitely power them in car. take any old 4 channel amp that does 75x4, bridge it, use each bridged pair as a channel, theres 150 rms x 2 @ 8 ohms
some focal tweeters run at 6 ohms.
aaaaaaalso, lots of ht drivers have varying impedances throughout the frequency range, ive seen ht towers that are 8 ohms at 4 khz, and 2 ohms down at 50 hz
if he has the speakers already, likes how they sound, and is willing to put in a proper install, then i say go for it
also, so what if its 6 watts. ive seen some serious efficiency come from some ht drivers
by the way, this is the first nd probably only post ill do this month
im moving into my new place and havent hooked up the internet yet, waiting for my paycheck
Old Aug 14, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
I have done it, when i was 16, I am 27 now. But I had 2 technics 3 way boxes and I hooked them up to an old amplified EQ in the car, was a 79 chevette BTW. bass was loud and I had cheap 6x9s on the deck, an old turn dial 8 track setup.
Old Aug 14, 2004
zen_master's Avatar
there we go. you just have to know how to do it correctly....... lol..
Old Aug 15, 2004
Mystic3030's Avatar
You asked about the stock radio...and I said no, it really wouldent work with the radio. Of course you can do it with an amp....
Old Aug 15, 2004
zen_master's Avatar
^^ lol, that's true........
this is interesting though...cos' i got few speakers laying around me....
however, they're 6 and 8 ohms...
Old Aug 15, 2004
i meant the whole speaker, not just drivers. i would put money down that 5 "stock HU" watts going to a HT speaker in the trunk would not sound so good if he did it. there is a reason many people even keep the stock speakers running off their deck when they install aftermarket speakers, they don't perform that poorly for what they are.
Jeffdp
Aug 5, 2015 11:38 AM
Jeffdp
Jun 18, 2015 06:18 PM
Galvezj11
Jun 17, 2015 04:13 PM
PimpBot5000
Nov 26, 2001 07:15 PM
BabyLX
Nov 16, 2001 05:53 PM
