Don't know where to GROUND your AMP?
Old Aug 10, 2004
Mr.Modify's Avatar
Exclamation Don't know where to GROUND your AMP?
Alot of people tend to ask this question so i just took a picture a minute ago for someone....What you do is drill a screw into the metal piece under the carpet and you got your ground. I hope this help's some of you
Old Aug 10, 2004
civic01vtec's Avatar
i ususally use the bolts for ur seat belt brackets
Old Aug 10, 2004
Mr.Modify's Avatar
Well you STFU....this is easier.....at least i think it is
Old Aug 10, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Good suggestion.
What about a good location for mounting the fuse under the hood?
Old Aug 10, 2004
Mr.Modify's Avatar
Originally Posted by MrWong
Good suggestion.
need a picture of that to?
mine kinda rests on the battery........ the wires are ran along the driver side fender.
Old Aug 10, 2004
make sure u use some white lithium grease so it won't rust
Old Aug 10, 2004
MrWong's Avatar
Bushido
a pic would be nice.
Thanks
Old Aug 10, 2004
takumi's Avatar
takumi is on a distinguished road
Thanks
There is a pic, check the first post.
Old Aug 10, 2004
MegaHurtz's Avatar
lmfao
i grounded mine on that hump too, didn't even need to drill, i just found a screw that fit and used one of the holes that was already there
Old Aug 10, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
I have 4 places already drilled, stripped and greased where I have grounded my amp lol... I move my stuff around a lot. Now, I'm building a new amp rack that's integrated into the sub enclosures. I think I may keep it a while though.
Old Aug 10, 2004
tfnaaf's Avatar
BLDNPSI Mod
here is where i mounted my circuit breaker, its the plexi glass mount down by the radiator
Old Aug 10, 2004
MegaHurtz's Avatar
I have my breaker on top of my stock air box
Old Aug 10, 2004
fonto's Avatar
The LA Clipper
I'm grounded on that hump too...I have like 4 things grounded on that hump too
...just please no one drill ANYTHING under the rear seats...please
Old Aug 11, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
Good spot Modify - I grounded mine underneath the larger seatbelt bolt, but I'm running 4 gauge from my distro block to ground. Was your spot bare metal or did you have to sand paint?
Old Aug 11, 2004
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
Me too.
Old Aug 11, 2004
Mr.Modify's Avatar
I didn't sand....i just drilled
CarStuff
Dec 6, 2020 12:52 PM
roverben
Jan 21, 2019 05:16 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
