Don't know where to GROUND your AMP?
Alot of people tend to ask this question so i just took a picture a minute ago for someone....What you do is drill a screw into the metal piece under the carpet and you got your ground. I hope this help's some of you
Originally Posted by civic01vtec
i ususally use the bolts for ur seat belt brackets
Well you STFU....this is easier.....at least i think it is
Originally Posted by MrWong
Good suggestion.
What about a good location for mounting the fuse under the hood?
need a picture of that to?
mine kinda rests on the battery........ the wires are ran along the driver side fender.
lmfao
i grounded mine on that hump too, didn't even need to drill, i just found a screw that fit and used one of the holes that was already there
Electric Boogaloo...
I have 4 places already drilled, stripped and greased where I have grounded my amp lol... I move my stuff around a lot. Now, I'm building a new amp rack that's integrated into the sub enclosures. I think I may keep it a while though.
Originally Posted by Coop
Good spot Modify - I grounded mine underneath the larger seatbelt bolt, but I'm running 4 gauge from my distro block to ground. Was your spot bare metal or did you have to sand paint?
I didn't sand....i just drilled
CarStuff
Dec 6, 2020 12:52 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
