What not to do
Old Aug 10, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
Talking What not to do
Hey put an OBD-II code reader on the car and said I'm throwing a code in cylinders 1-4 for missfiring... and he said the only way it'll do that missfiring is by boosting it ... even barely... and since i have no fuel mods he said it's detonating and i Prob have a ****ed Cylinder Head and bad ring lands now...
what do you Turbo GURU's say to this???
Old Aug 10, 2004
taz757's Avatar
Um. How about this?
Remove the spring from your wastegate so you're not boosting at all. Then get you some fuel management. You can't add more air without fuel.
Old Aug 10, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
wtf! you're running a turbo without any extra fuel? ... that's running crazy lean
Old Aug 10, 2004
REDchirp's Avatar
Just called me back said my motor is blown, first cylinder is done only has 50 PSI readin on a compression leakdown... piston is cracked... I dont' ****ing get it... i had it max of 3500 RPMS.... is this crazy?? WTF do i do???
Old Aug 10, 2004
HyaBoosta's Avatar
I threw codes for misfiring in my car when i over reved it by missing a gear. But after I cleared them the same day it never came up again. and my car runs fine. But im not sure, you are under boost and you do need a fuel system. I have to agree with taz. take out the spring and don't boost. Just get the FMU and inline pump and safc or emanage.Sounds like it probably is detanation. do you have a boost controller? How did you set your boost down?
Old Aug 10, 2004
HyaBoosta's Avatar
dam bro sorry to hear, but it looks like you got a little too hyped up about the turbo and put it on before you had everything you needed.How long did you run the car under boost for?
Old Aug 10, 2004
REDchirp's Avatar
an hour.... everything in my kit so far is worth over 3G's... i'm just gotta get a new motor... sell the car... sell the turbo kit... get a turbo'd car from the factory... done deal...
Old Aug 10, 2004
Pharoh's Avatar
Bobaganoosh!
Sucks man...
information is king.
Old Aug 10, 2004
reytito's Avatar
what were yo doing to get more fuel? anything at all?
Old Aug 10, 2004
REDchirp's Avatar
Nothing... Kit is for sale if anybody wants it... I've invested almost $3500 in the kit plus all the labor i paid for custom fabrication... and now i know the only thing the person that buys it needs is an FMU and Inline Fuel Pump and tune... but if your interested I'm asking $3000 OBO.... lemme know guys if your interested...
Old Aug 10, 2004
Havok2k1's Avatar
Wicked Pissah Admin
Sorry to hear it, K20 time....
Although, I edited the title so others will learn from your experience...
More air + no more fuel = bad
Old Aug 10, 2004
deciuss's Avatar
Boosted Auto
so if you just undo the spring then you wont have any boost but you can have the kit on still and run the car fine?
the reason that i ask is sf is sending my kit to me without the fuel stuff since they dont have it yet and are going to send it latter but i want to get some of this kit put on befor im off to college and have no garage to work in
Old Aug 10, 2004
civic01vtec's Avatar
how much boost were u running ?
I ran 10psi with no fuel system for about 1 wk b/c i had no idea my fuel pump wasn't working.
You will to part anything out........what all u got ??????
Old Aug 10, 2004
Big Baller L's Avatar
Nugget Garage Since 2004
aww man that sucks....i hate seein projects go bad. Keep ur head up tho! What parts do you have?
Old Aug 10, 2004
MadWheel's Avatar
Premium Boosted Member
I need to do a compression test on my motor... I ran it a couple times with the pump shut down.
I'm sorry to hear what happened man, but you need to understand... we told you not to drive the car and you didn't listent. We said to kill the boost but you still ran it...
Do the research before you boost your car, not after. Sorry for your misfortunes, if you need help if you decide on replacing/fixing the motor then let me know. I'd be glad to help.
Old Aug 10, 2004
tfnaaf's Avatar
BLDNPSI Mod
that does suck, but you MAY want to get a second opinion. Is it running REAL bad now or was it that you just thru the code and took it to get checked? And btw there is a local 7th gen running boost on his and the last i knew he had ZERO fmu on it.
Old Aug 10, 2004
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
This may not be the time to ask, but do you have any pics?
Old Aug 10, 2004
HyaBoosta's Avatar
Is it running rough? or did it just throw the code? and after you clear it does it come back on?
Old Aug 10, 2004
REDchirp's Avatar
THe motor itself didn't really BLOW guys... the head isn't cracked if i really felt like it I could buy a new piston from Honda for like $50-60 and have it installed and everything would be cool... cylinder 1 read at 90 on the compression test where the 2nd, 3rd, and 4th all were perfect at 210.... the first cylinders piston cracked and cracked it's lands thats why the smoke was coming out and oil in in the DP... I just don't feel like dealing with all this bullshit of spending more money now to buy a whole new set up pistons to have a built motor and then sleeve it, then get a return system which is truly ideal for our cars not to be ****ed up and detonate, and then i'd have to Tune the bitch, and that all total's up to more than a Freshman in college wants to pay or can pay.... i'm selling it... It's all in prefect condition not even 300 miles on it... 250 or so from the person before me... and not even 50 from me... I have spent a lotta money on getting everything custom to work PERFECTLY hence IC piping is the best i've seen on this sight.. nobody can touch mine and keep the PS and A/C like i did.... and I just want a car that is built from the factory that is already turbocharged and can handle lots of boost on a stock block which in the end is a lot more OOOPS proof....
and NO pics... there's nothing to see... i'm not taking it all apart... just gonna get a new motor from honda and sell the car and kit separate and go on with life...
Old Aug 10, 2004
REDchirp's Avatar
Guys... the compression test showed as follows:
Cylinder #: 1-------2--------3---------4
__________90------210-----210------210
Old Aug 10, 2004
HyaBoosta's Avatar
can you post pics of the turbo kit it?
Old Aug 10, 2004
REDchirp's Avatar
check my forsale posts... has some pics for starters... i'll have pics of the IC setup so all can Jerk a few out to it tomorrow afternoon lol...
Old Aug 10, 2004
MadWheel's Avatar
210? The honda manual states that it should all read at 135. Maybe somethings up. Mine read at 180ish though, so I may be in the same boat as you. I'm just curious why the manual states that it should be 135 when me and you are both getting close to 200. I made another thread about it.
Old Aug 10, 2004
REDchirp's Avatar
Yea... that's what i got when my guy did the compression test...
Old Aug 10, 2004
MadWheel's Avatar
I'll be doing more research in the mean time to figure out what's up with the car. Luckily I know a bunch of other 7hgen oweners so I'll do a test on one of their lower mileage NA cars and see what happens.
Old Aug 10, 2004
REDchirp's Avatar
Thank you... this is true even though i don't really like what havok decided to change the title of my post to, but whatever lol... that's what ya get ta do when ur a mod i guess
Old Aug 11, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
You might be loosing compression from the head gasket they will blow before anything else and you will get smoke. Also before I installed my missing link map isolator I got that same code several times. If the MAP reads boost it will show misfire on all cylenders. I lost compression when I blew the waterjackets of the head gasket inside my engine. It blew on cylender one both times. Might just be that. Dont give up. Pull the head and see might just need a new headgasket and a map isolator.
Old Aug 11, 2004
REDchirp's Avatar
how expensive is it to take it to somebody, and have them take the head off and see if I blew a Headgasket? I just find it too weird for it to just be the headgasket when the 2nd 3rd and 4th cylinders all have the same compression reading and the 1st one just plain sucks...
Old Aug 11, 2004
HyaBoosta's Avatar
well if you just want to sell the car you might as well save yourself some money and just fix what needs to be fixed and get it running again.
Old Aug 11, 2004
REDchirp's Avatar
thats what i'm doing.... ordered in my new Oil Pan and gasket today, everything will be back to the old wayz by tomorrow and i will be unhappy and slow again for a lil while to i fully sell mine and finalize the deal on my new car... thanks man
