Wiring two amps?
Old Aug 10, 2004
Ballatician's Avatar
Ballatician has a spectacular aura aboutBallatician has a spectacular aura about
Wiring two amps?
How do you wire two amps together?
Old Aug 10, 2004
orso's Avatar
orso is an unknown quantity at this point
what do you mean by "together"?
Old Aug 10, 2004
What I mean by together is can the amps be wired together somehow without having to get new gauge, ground, and remote wires for the 2nd second amp.
Old Aug 10, 2004
orso's Avatar
I think what you are saying is that you want to power both amps without having to rewire everything. as far as the remote wire all you have to do is splice into it. unfortunatley the only way to power the amps and ground them is with additional wires. i did this by running 4 gauge from the battery back then using a distribution block with 8 guage running to the amps. i also used a distribution block for the ground as well 4 gauge from a secure point in the car with 8 gauge running from that. this is the best way to do it IMO.
Old Aug 10, 2004
doubledeuce2k2's Avatar
yes please use a dist. block. it's worth it.
Old Aug 10, 2004
Where does the distribution block sit?
Old Aug 10, 2004
shmik1's Avatar
anywhere, close to the amp.. it has 2 screw holes its not very big, sounddomain.com has em...
Old Aug 10, 2004
orso's Avatar
basically run you power wire to the trunk. mount your power dist. block somewhere close to your amps. i am assuming they are in yourtrunk so a good place would be on the back of the seat or on the box. samething you ground dist. block. you only want a maximum of about 3 feet of wire going from the dist. blocks to the amps. so you have to mount relatively close to the amps. with this kind of power i would also consider a power cap unless you have a upgraded battery or alternator.
Old Aug 10, 2004
Ok, thanks for the help guys.
Old Aug 10, 2004
orso's Avatar
no problemo! hope everything works out for ya.
Old Aug 10, 2004
KnocturnalEM2's Avatar
I am your Mom's Hero!!
What kind of amps are you wiring? Some bass amps (i.e. JL Audio) like a clean 4 gauge power wire!! Just a thought!!
Old Aug 10, 2004
I'm wiring two bazooka mono amps.
Old Aug 10, 2004
MegaHurtz's Avatar
Use a distro and run say 0 gauge from the battery to the distro and then like 4 from the distro to the amps. Always go from a bigger main power wire to a smaller from the distro to the amps.
You need to run 2 seperate grounds, either use a ground block or ground them both to the same spot.
The remote wire you can run from one amp to the other
sch2cm
Jul 21, 2015 09:58 PM
Civic65
Jul 19, 2015 10:13 AM
phantommaggot
Engine start problems
Jul 12, 2015 12:55 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
robbie374
Jul 7, 2015 02:56 AM
