AUTO tranny slipping cause of vafc
Old Aug 9, 2004
CivicChick01's Avatar
CivicChick01 is an unknown quantity at this point
Can my tranny be slipping cause of my vafc the mechanic that is doing my car said that once that is tuned we shouldnt have a problem, I just got my turbo kit on and I dont know if that can be the problem or not please help!!!!
Old Aug 9, 2004
dezod's Avatar
7thgen Power Maker
Turbo Creates Extra Tq & Hp The Auto Tranny Is Not Built To Handle. Therefore, Tranny Is Going.
Old Aug 9, 2004
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
oh bte vafc is not deisgn for 7th civic. you have to get vafcII. take it easy on the tranny on start up, don't floor it during the 1st and 2nd gear.
Old Aug 9, 2004
I understand turbo means more hp and torque, it is a brand new honda tranny, he said the the valve bodys arent knowing when to work cause of the vafcII saying that it is the ecu making it do this
Old Aug 9, 2004
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yep. turbo or not, 7th gen trannies are notorious for slippage/breakage
Old Aug 9, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Get a tranny cooler
Old Aug 9, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
you're dead on man! I'm about to pop my tranny soon, I already had slippage about 8 times on 3rd gear already and it was so bad... the sound of my tranny slipping is the must aweful sound i've ever heared
Old Aug 9, 2004
Get a tranny cooler and put the car in neutral when stopped at a light so it doesn't heat up as much. VafcII only allows you to change fuel and vtec engagement.
Old Aug 9, 2004
WhiteCastle's Avatar
hes been running it without a tranny cooler....is he nuts?
I am running tranny cooler right now in prep before I even get the turbo'd just so see the results
Old Aug 9, 2004
Ramones's Avatar
Ramones is an unknown quantity at this point
If you're are not driving in constant stop and go traffic and stalling the torque convertor to raise the RPMs for launches then there is no reason for your tranny to overheat. If you are doing these two things then yes get a tranny cooler and monitor your temps. Tranny slippage is a symptomn of a possibly going tranny.
And it is torque that kills transmissions (manual or auto) not horsepower.
Old Aug 9, 2004
Havok2k1's Avatar
Wicked Pissah Admin
ACTUALLY, if you want to be nitpicky (sp?), HEAT kills transmissions......
Old Aug 9, 2004
well what it comes down to is e 5 speed swap needs to be done if any1 can hook me p with a place to get all the parts it would be greatly helpful
Old Aug 9, 2004
All you need is a tranny cooler. Heat kills 90% of all transmissions that go bad. It's easy to install, and mine only cost $50. Don't waste thousands on a conversion that probably won't work perfectly anyway.
Old Aug 9, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
Aftermarket turbo's are hell on Auto Tranny's...Manual Tranny's can take a lot more abuse...sorry...better start looking for a high performance rebuild...
juror
Suspension DIY
Jul 30, 2019 03:28 AM
0396
May 4, 2016 07:14 AM
JetsterDajet
Aug 15, 2015 08:07 AM
beeemerdude
Jul 23, 2015 03:53 PM
Jul 12, 2015 11:54 AM
