HELP!!!.....Apexi VAFC 2 problems
Old Aug 5, 2004
Vinh's Avatar
Exclamation HELP!!!.....Apexi VAFC 2 problems
yea yeah.....i read the 10,000 posts already
my car's CEL came on when i turned on car
my car rev limits at 3.5-4k rpm
my car idles like crazy and the rpm drops to zero and car turns off
vtm wire is connected
so now what do i do?
Old Aug 5, 2004
Not that it matters considering you have a civic, but did you change the vtec engagement point? I tried that and the engine didn't feel or sound right. Made growling sounds when the vtec should have been on but wasn't. So set the vtec back to stock.
Either you didn't hook up the wires properly, or you didn't do the initial setup like I keep telling you! Disconnect the battery, reconnect it, and turn the car to ON (do not start the engine). Now you need to adjust the settings on the vafc.
As far as initial setup...
Just before doing initial setup, while turning ignition on press gas pedal down for 10 seconds, then release for another 10 seconds before moving on to initial setup settings step. This step takes care of step 6 below...
1. Sensor = 06 & 06
2. Cylinders = 4
3. Throttle Voltage = automatic
4. Throttle Type = Arrow pointing NE
5. VTEC Type = 3
6. See above...
7. VTC = N/A
8. Turn off ignition and your settings get saved
Old Aug 5, 2004
Vinh's Avatar
i just found out that i don't have vtec and EX models have it
vinh = owned
sike......i have an hx and everything works fine now
Old Aug 5, 2004
Haha. Cool. So what was the problem?
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
CivicPunker17
Dec 1, 2001 06:58 PM
Jimmy24
Nov 30, 2001 08:29 AM
mattskav
Nov 8, 2001 10:44 PM
