Could ripped Hayame rubber rings cause noise
Well basically I ripped almost every rubber ring on the hayames during install and mine are noisey so I am thinking that may be it, is that possible?
I check all the perches to make sure they are tight and still makes noise.
Yes, it's an Acura EL
Yeah sounds like that's your problem. All of mine are still intact thankfully. Also make sure the top nut (the one atop the shock, in the middle) is on tight. Mine were shipped loose...the noise was scary.
Originally Posted by halflife
Do you know what part #'s would be for the Hayame?
thanks all for your help
Those things are the same things you use with blenders.
Hayame should've kept them plastic. There was nothing wrong with them in that form for the V1s. Thread Starter
Originally Posted by TeLLy
both.
Do you guys know if there is a certain way to install the top part of the rear, meaning those 2 bolts that go up into the trunk, they are like on a triangle and not sure if it matter how it goes up there?
Thanks again everyone for your help.
Well i have my two new front hayames in the mail today, mine 2 front shocks were defective, so hopefully these 2 new ones i got in the mail lastnight will work. I'm ready to have a car to drive again!!
15EXCoupe
Jul 30, 2015 12:59 PM
Green02civic
Jul 27, 2015 10:48 PM
DerbyDad03
Jul 27, 2015 11:34 AM
estes53
Jul 20, 2015 10:43 PM
muttleytm
Jul 8, 2015 04:13 PM
