Help!!!!
Old Aug 3, 2004
lounge_8180's Avatar
lounge_8180 is an unknown quantity at this point
Help!!!!
ok i blacked out my cleared headlights today. i thought everythging is good and gravy until i turned on the lights. the middle light on my passenger light is not workin and the front right turn signal is not blinkin like it should. the rear turn signal is blinkin but it blinks like i have hyperblinkers. and inside the car the arrow signal is blinking like i have hyperblinkers also. everything on the driverside headlight is working properly. what do you guys think i did wrong?? i noticed that there's four connectors 1 for the main lights 2nd is for the middle one(not sure about the name of it) 3rd is for the turn signals 4th is the brown color one( not sure where it hooks up). the brown connector on the driver side is connected somewhere but on the passenger side i couldn't find anything to connect the damn thing. and i dont remeber disconnecting it to anything. someone please help me!!!!!! i don't want to go to the dealer and pay them plus im really short with my budget right now. so if you know anything that can help me out or you know wht i did wrong pls reply to this.
Old Aug 3, 2004
Lynk's Avatar
when i was done clearing my headlights, i remember my right blinker blinking like a hyperblinker like you described. Fixed it by plugging my blinker back in... turns out i had forgoten to plug that one back in. So I'd suggest to check if everthing is plugged in right.
But from what you said i think you already may have checked that. So Maybe check the fuses.
Also, not sure what you mean about 4 connectors, you're only supposed to have 3...
Old Aug 3, 2004
ya there are three connectors to the headlights but there this brown connector left out not for the lights but i know it suppose to go somewhere. i dont know where to connect it to and i think thass the reason to all this. i'll probably take a picture tom but not sure how to post it.
Old Aug 3, 2004
Lynk's Avatar
yeah, it's gotta be some unpluged wire... although i know know why it was unpluged in the first place cause it doesn't attatch to a bulb in the headlight... so it's gotta be something else. But it's most likely that brown connector
Old Aug 3, 2004
Shu's Avatar
Shu
Shu is an unknown quantity at this point
The turn signal also "hyperblinks" when no bulb is plugged in...make sure the bulb is in all the way and that it's not burnt out.
The extra brown plug is for expansion I think (OEM fog light kit)... I also noticed mine's not attached to anything, but everything works fine on mine...
Old Aug 3, 2004
smokedcivic's Avatar
"SLIPSTREAM R"
smokedcivic has a little shameless behaviour in the past
the brown connector is for the OE fog lights...
Old Aug 3, 2004
Liro's Avatar
Back from the dead
thats wierd...but like shu said, make sure none of the bulbs are burnt out!
Old Aug 3, 2004
Shu's Avatar
Shu
Yep...burnt out bulb = no bulb = no resistor for circuit = hyperblinker effect
Old Aug 3, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
If that middle bulb goes out, it will mess up the blinkers. when i did mine the middle light was out and the blinker was doing the same thing, I replaced the middle bulb first and the blinker started working again.
Old Aug 3, 2004
ohhh fawk!!!! does that mean that i need to open the whole headlight assembly again??? i think shu is right that i didn't push the bulb all the way in... i just checked the headlight now and i tried pulling the socket for that bulb and i coudn't. can you take that thing off or do really have to open the whole headlights?? thanks for replyin everyone.....
Old Aug 3, 2004
SlimmKidd's Avatar
SlimmKidd is an unknown quantity at this point
R you new?? You don't have to open the whole headlight assembly.
Old Aug 3, 2004
i figured it out how to take that middle bulb out without taking the whole assembly apart... i feel so dumb now thanks to slimmkid!!! lol but ya i think i broke the bulb that's why. ayt thanks again!!!!
Old Aug 3, 2004
Liro's Avatar
Back from the dead
we all gotta start somewhere man, dont let slim get to you, he is too wise for our good it seems....
if you have any more problems post before you do anything! goodluck man!
Old Aug 3, 2004
well its slimmkid that told me how to take the damn thing out. i meant to thank slimm for telling me how to take it out, my post just didn't come out right. but ya im learning nuff from this board and everyone seems to be very helpful when you have questions.
Old Aug 4, 2004
TeLLy's Avatar
Yes, it's an Acura EL
If not for this board my EL would be stock, I'd have a whole PILE of money and my own house. But instead I've learned and spent so much modding my car. Thanks 2k1civic....I think...
Old Aug 4, 2004
Liro's Avatar
Back from the dead
i guess i owe the forum too cause i wasnt gonna mod the car at all...i guess im in the same boat as telly though, i would probably have moved out by now and my car would be stock....
thanks 7thgen, kinda....
