Headlights - help....need opinon
Old Jul 28, 2004
Liro's Avatar
Back from the dead
Question Headlights - help....need opinon
im thinking about going to gun metal finish for my headlights instead of just the normal clears...
what do you guys think? those of you who have actually seen my car
Old Jul 28, 2004
Lynk's Avatar
something like this?
i like it on silver, and would probably look goot on a black car as well!
do it! he he
Old Jul 28, 2004
TeLLy's Avatar
Yes, it's an Acura EL
I just posted this elsewhere, but I can't find the link right now:
- mask off what you want to keep silver
- use Krylon Fusion black for the base (2-3 coats), then one light coat of Duplicolor Wheel paint in Graphite to finish it. That way it looks black from afar, and gunmetal-metallic-glossy up close. No need to finish in clearcoat. If you don't like the textured look, put on two coats of Duplicolor Graphite (sand between coats) then sand and clearcoat several times. Finish off with rubbing compound. I find this too shiny for my taste, but it's up to you, my little friend.
Old Jul 28, 2004
TeLLy's Avatar
And yes, a DARK gunmetal (like the shade Rota uses on their rims) looks faboo on black cars. And red cars. And silver cars. And green cars. And white cars. But not hot pink or baby blue. Those cars don't deserve headlights.
Old Jul 28, 2004
Liro's Avatar
Back from the dead
thanks guys!
Old Jul 28, 2004
Pharoh's Avatar
Bobaganoosh!
So true.....So true.
Old Jul 28, 2004
Liro's Avatar
Back from the dead
so i should do it?
Old Jul 28, 2004
Pharoh's Avatar
Bobaganoosh!
Originally Posted by Liro
so i should do it?
On a black car? ummmmm...YES!
Old Jul 28, 2004
Liro's Avatar
Back from the dead
i think its nice...but i also like the totally clear lights too....hmmmm.....
i do trust telly and freddy's opinion though....
Old Jul 28, 2004
Pharoh's Avatar
Bobaganoosh!
*ahem*
Old Jul 28, 2004
Liro's Avatar
Back from the dead
i stand by what i said....hahaha
and pharoh!
Old Jul 28, 2004
Liro's Avatar
Back from the dead
i like freddy's but im actually trading mine up with someone's who are already done....but the only chrome part left is the h4 reflector....
what do you guys think of that?
Old Jul 29, 2004
lounge_8180's Avatar
lounge_8180 is an unknown quantity at this point
im planning to do the same... .hey telly, how long do you leave it in the oven agai?? 2 minutes right??? and what temperature do you set it at?? im planning to do it myself and hopefully i don't f@kc it up!! oooh ya whats the silicone sealant do you use?? thanks
Old Jul 29, 2004
GuSTo's Avatar
GuSTo is an unknown quantity at this point
liro, give me a shout, i have a set i can trade with you too
i'll even put the orange back in....we'll work something out
Old Jul 29, 2004
Pharoh's Avatar
Bobaganoosh!
Now I know why Telly is so much faster than Freddy....he uses the oven..haha. Freddy uses a blow dryer.
Old Jul 29, 2004
Shu's Avatar
Shu
Shu is an unknown quantity at this point
Liro man, I told you it looks much wickeder darkened on a black car
Just trade with me dammit!
Old Jul 29, 2004
1llmatic's Avatar
1llmatic will become famous soon enough
the gunmetal headlights are pimp.
Old Jul 29, 2004
smokedcivic's Avatar
"SLIPSTREAM R"
smokedcivic has a little shameless behaviour in the past
i did mine white but gunmetal for sure looks tight...
Old Jul 29, 2004
TeLLy's Avatar
I'm gonna copy my response to THIS thread:
Originally Posted by WhiteCastle
what kind of paint are you guys using? I was thinking of painting my headlights white ^.^ matching the car and junk
Not enough contrast between the chrome inner reflectors and the white IMO - it won't really stand out till you're really close to the car. But if you wanna colour match, just grab some primer and then go to a bodyshop supply place with your paint code, and tell them to do you up a spray bomb. Should be pretty cheap. I myself recently redid my headlights - sanded off the old paint, then primer, black base coat, and IS300 grey from the local bodyshop supply place.
I just wanted to reply to a few other comments here:
- You don't really need high heat paint for headlight housings. It doesn't get THAT hot in there. That said, if you were to do a white finish, I dunno if it'll go yellow in time. One other thing to worry about with white housings is if you get condensation and it happens to stay in there for a while, you'll really be able to see any kind of mold or discoloration that happens as a result.
- I used to use high heat barbecue paint (seriously) to paint housings black then a coat of Duplicolor Graphite wheel paint to give it a gunmetal glossiness. Since then, I've moved on to Plastikote black for blacked out headlights, and if I want a gunmetal finish, I'll spray on a coat (more like a dusting) of Duplicolor Wheel Paint (graphite)
- Plastikote paint sticks to plastic, so no need to sand/primer the (plastic) chrome pieces, and it gives a finish that's plenty glossy, especially once you place the lens back over it. If you really wanna get shiny about it, plan to have your headlights off for a couple of days, then primer-sand-paint-sand-paint-sand-clearcoat-sand-clearcoat-sand-clearcoat-sand-clearcoat-sand-rubbing compound. It'll come out looking like a bodyshop did it. But I don't think you'd be able to tell the difference between the two unless you were comparing cars side by side.
- I do sedan headlights in the oven by popping them in at 300F for 3-4 minutes. Coupes, same temperature for 2 minutes at MOST. Heck, I did a coupe headlight clearing on a really hot day and all I did was pop the clips and open it outside. Make sure it's 300F, not 300C, especially with those fancy schmantzy ovens with the digital displays! A friend of mine melted his because he didn't know which was which - I was in the room, and the smell and sight of a drooping headlight is heart-rending. I don't think I've ever had to wait longer than 5 minutes total at 300F for a sedan headlight. You really should check them at 3 then if you can't open them without minimal effort, pop them back in for another minute. Otherwise you risk warping/permanently bending the rear housing, which will of course result in the headlight not resealing properly, which leads to leakage and condensation.
- When resealing, I press the headlight housing and lens together, then pop it in the 300F oven for 3 minutes at most. As soon as I get it out I use spring clips to press the seams closed. They look like this:
Once the gap is closed up, for coupes you should be good to put the clips on. However, for sedans, and the paranoid coupe owner, I use Permatex Gasket Maker (the grey stuff) and run a bead all around the headlight:
My headlights are still condensation free from this method, and I've hit them with thunderstorms and pressure washers.
- One more thing, make sure you don't have any dust on the inside of the lens when you reseal. You'll notice it like two days later and it'll drive you mad. I keep either one of those air-cleaner spray cans or (if I have money that week) one of those swiffer refill cloth thingies. You don't want to use a paper towel (wet OR dry) or just any random cloth, as it'll put tiny scratches on the inside of the lens. I used to use terry cloth towels but the ones I got always left a tiny piece of lint on the lens so I had to use an air can anyway. Bah.
Old Jul 29, 2004
Lynk's Avatar
that's alot of detail... where would we all be without telly! he he
when i painted mine i just taped off what i didn't want painted, then used a primer, then a high performance wheel paint (gunmetal. Same one i used on my stock si wheels, and my upper and lower grills) and just finished it off with some clear coat.
Old Jul 29, 2004
Pharoh's Avatar
Bobaganoosh!
Ya..where are the pics!
Old Jul 29, 2004
Liro's Avatar
Back from the dead
well im just trading mine up...if i do decide to do the gunmetal....still on the fence..but everyone seems to be in favour of the gunmetal....definately something to think about
Old Jul 29, 2004
TeLLy's Avatar
[QUOTE=FreddySi]where would we all be without telly!QUOTE]
I dunno, laughing at a pair of bums duking it out in the park? How should I know?
Old Jul 30, 2004
thanks again telly!!!
Old Jul 30, 2004
Liro's Avatar
Back from the dead
the true mod monkey!
Old Jul 31, 2004
Shu's Avatar
Shu
Swap is done...Liro now has a full coupe headlight conversion!
Post up some pics!
Thanks for your advice yesterday Telly, worked like a charm...I'd probably still be sitting there with my little hairdryer if Rob didn't call you...
Old Jul 31, 2004
EŽik's Avatar
^^ hair dryer, a heat gun would work well wouldn't it.. I actually have had one sitting in the back of my car for almost a year... Maybe I should give it back to the guy who owns it.
Funny thing is, he hasn't asked for it back. Whenever I called him he'd be like, "Dude, whenever your in the neighbourhood"
His shop is in Rockland.... for those of you who don't know where Rockland is from Ottawa, it's about a 45 minute drive East on the 174 hehehe
Old Jul 31, 2004
TeLLy's Avatar
Word. I"m tellin ya guys, oven is the shizznat. Heat gun takes too long for sedan lights. Fine for coupe lights though.
Old Aug 1, 2004
EŽik's Avatar
It's wierd how they seal the lights differently on coupes and sedans... Why don't they just make them the same
Old Aug 1, 2004
TeLLy's Avatar
Cause they knew I was buying a sedan and nobody makes life easy for me.
