rear air struts (easystreet)
Selling the rear air strut setup from easystreet. Besides air ride tech (which doesn't have a kit for our cars) easystreet is suppose to be the best company for air ride (check the forums). The setup I have rides great, much better than the ground control coilovers I had. Its also good for getting around the city and all the potholes and dips. I've put about 4000 miles on the bags and haven't had a problem yet. No leaks or rubs. Bolts right up, pull the old strut and spring combo out and mount it in. Air inlet is on the top too so the air line won't leave your trunk, and also makes for a short amount of line and VERY fast dump and fill. Made for 1/2 air lines. Selling to give up ride quality and go lower with a regular style bag. http://www.airliftcompany.com/easyst...indexframe.htm selling for $400
i don't have a dig camera but I will try to get my buddy to use his camera phone. The rear will meet the tires on my 17" wheels and raise to a good bit more than factory. One guy on here did have a way to modify them if you wanted but its kinda fun to go jacked up
Here are some pics. Sorry it took so long to post had to borrow a dig camera. Thats about how high and low it will go without modifying the setup. They also have adjustable struts (you can see the **** in the picture).
What do you get for $400??? I might be interested!!! What do you want in trade???
I have projector headlights and an axel back exhaust I could trade with cash. Let me know.
$400 obo for both of the rear air struts. Its a complete setup so just take out the factory spring and strut as one piece and bolt this one in. Takes about an hour tops if you're any good with taking out the rear struts. Its got the quick connect fittings for the 1/2 lines. Then run the lines right into the trunk to the valves or where ever you are putting the valves. Ta Da..... the rear is complete. I've already got exhaust, but what kind of headlights are they? Any pics?
Hey Bagged-
Just wanted to know what all came with them from the last post. I know you said just the bags, correct, no tank, valves or compressor. Probably going to use it with the new bags??? Would I be able to put these in and fill them up and cap off the line until I get the rest of the stuff I need??? Would that work?? Just curious. I will be getting the rest soon, just wanted to get something in the rears, becaude my HR's are saggin bad. LMK. The lights I bought from another member a while back and they came to me with loose projectors. I had pulled them apart at one time and fixed them, at least for the time being. Since I had them on the car I think my fix came loose and they need to be taken back apart. I can do this if you still think you want them. I have all the stuff to fix them, for good this time. I just need to pull them back apart this weekend. While I have them apart I can paint the insides any color if you want and we can work out a deal if you think my plan would work for the next month or so with the bags. The lenses are pretty clean, not too many scuff marks. i will polish them up for you also. Here is a pic I have with the eyebrows on. I beleive iw will have to take them off to get them back open, but here you go.
let me know what you think!!!
Any bag over that long of a time will leak down a little. You would also have trouble trying to get enough air in and cap it off at the sametime without all the air shooting out. One thing you could do in get some extra 1/2 inch line and an adapter that had a valve stem on it and fill them up manually at a gas station. I dont know how well that would work but I know some of the old cars use to have them done that way. What do you mean by a loose projector? What happens when they get loose? I'd be a little scared of getting moisture in them b/c it rains a LOT around here. The humidity is really bad too. Think I would have a problem with them?
