Oil Pan Is Stuck!!!!
Old Jul 14, 2004
REDchirp's Avatar
REDchirp should not be trustedREDchirp should not be trusted
Talking Oil Pan Is Stuck!!!!
I need help..... what can i do to get it off... i have all the nuts and bolts off and can't get anything to wedge into the little section to pry it off... what can you guys say to help me out here!!!! I need this info guys!!!!
Old Jul 14, 2004
civic01vtec's Avatar
that last person i helped get off their oil pan was Sam
anyways.............there are little tabs on the oil pan u can get on with a pry bar and beat the pan with a rubber mallet.
Old Jul 14, 2004
ic u said that u can't get in there to pry..........if u turn u wheels to the left u can get in there .........or there is a tab on the pan towards the front of the car near the tranny.
Old Jul 14, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
just keep hitting it and pulling one it.
take a break then do it again
after a while from pulling on it you'll see it seperating a little bit cause the gasket sealent is loosing up. Then wedge a screwdriver in there and it should pop off.
?, how many bolts and screws do you count?
Old Jul 14, 2004
REDchirp's Avatar
I def have all the bolts and screws off but i'll try the turning of the left wheels.... thanks... keep the suggestions coming...
Old Jul 14, 2004
i used the tab that is towards the front of the car, near the tranny and got on it with a pry bar and beat the pan really hard with a rubber mallet. Took me about 5 min.
Old Jul 14, 2004
REDchirp's Avatar
OK... and i noticed on the back of the pan... well a little above the back side of the pan... it looks like there is a a plug, about the same size and my oil pan fitting that i'm gonna be using... it is a Hex Plug... does this go to the oil pan? and if i can get this plug out can i screw my fitting into there and go? lemme know... thanks!!!!
Old Jul 14, 2004
i have no idea what you are talking about.........the only plug is the drain plug. The oil pan fitting for ur return line goes on the front side of the pan.
Old Jul 14, 2004
REDchirp's Avatar
I'm posting pics of what i'm talking bout in a sec...
Old Jul 14, 2004
i hope its not the second bracket
because those should have been the first things off..
....::waiting impatiently for pics:::...
Old Jul 14, 2004
REDchirp's Avatar
Plug that i'm talking about...
and then the two ledges....
granted i don't have the best digital... but that gives you and idea of what i'm looking at...
Old Jul 14, 2004
REDchirp's Avatar
what is the second bracket?
Old Jul 14, 2004
there are two brackets on the passenger side that bolt to the tranny
i dont see them in the pics so i assume they are off
Old Jul 14, 2004
from those pics and me not being under my car, i can't tell you what that is exactly. What yr/model vic do you have ??
Old Jul 14, 2004
REDchirp's Avatar
Yea i took those brackets off... everything is off... my dad.... (owner still of the car) just doesn't want me to have to break the seal of the oil pan and was wondering if that plug went to the oil pan and the oil fitting could just be screwed in right there... but i will prob just go at it wit a rubber mallet... but if i go at it wit a rubber mallet it'll stop to come loose pretty quickly right??? i don't wanna be sitting there hitting it for an hour... lol
Old Jul 14, 2004
REDchirp's Avatar
2002 Civic EX Coupe
Old Jul 14, 2004
NoSpleeny's Avatar
NoSpleeny is an unknown quantity at this point
As soon as I unbolted my oil pan (there are like 15 bolts.. haha).. mine sorta just fell right off... It almost knocked me out.
Old Jul 14, 2004
REDchirp's Avatar
damn... mine is glued on... lol... but seeing as honda doesn't want loose leaking OIl pans i understand why...
Old Jul 14, 2004
Civictuner04's Avatar
Civictuner04 is an unknown quantity at this point
there shoould be a little lip that runs all along the edge of the oil pan. Get some vise grips, clamp them to the lip then pull down using ur body weight and stick a flathead screwdriver in. That worked for me.
Old Jul 14, 2004
REDchirp's Avatar
Thanks...
Old Jul 15, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
Mine came off pretty hard too, although I didn't have to pry it at all. After all the bolts were out I hit it with a rubber mallet alternating sides (front then back). After about 20 swings or so I just grabbed it and pulled the whole thing toward the front and it popped off.
Old Jul 15, 2004
REDchirp's Avatar
Awesome... i'm gonna try this when i get home...
Old Jul 15, 2004
REDchirp's Avatar
got it off!!!! banged on it with a rubber mallet... and then took a 14mm open ended wrench and stuck it in the front left corner of the pan where there was a good sized lip, and got leverage on it and pulled that baby right down... worked like a charm for me... thanks guys!!!!
Old Jul 16, 2004
ImportRacer2123's Avatar
K20 Member
hope you have honda bond.
Old Jul 16, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
^^^honda bond? i'm getting my oil pan off too... so is this a sealant like the silicone? can I use silicone? or do I have to buy a new seal from honda dealership? thanks!
Old Jul 17, 2004
player1002's Avatar
That's what I used too. No leaks here.
Old Jul 17, 2004
i used blue RTV..........no leaks for me
liagreenhalgh92
Jul 21, 2015 01:31 PM
Q-Bert
Jul 19, 2015 09:09 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
ballmich
Jul 9, 2015 11:59 AM
