Its normal for all SF t3 turbo?
I Brought the kit used soo.. i don't know. I have Air research t3 turbo but i dont know it is come with sf kit or someone swap it. It is normal for all sf turbo missing the some kind of screw whatever it called to hold down the end of wastegate rod? For mine i can take it out and put it back. I'm talking about that thing. pix
Retired - SoCal FI Mod
it's supposed to be a C clip that holds the rod to the wastegate acuator... look around in the box and try to find it... if not go call up SF or go out to a junk yard and pull one off of an old turbo...
If the rod pops off you'll just make 0 boost.
They normally come with the clips. That looks the T3/T04B but I'm not sure. What's the AR on the side of it?
You are talking about the pix right? I got it off SF website because i don't have pic of my turbo yet. I will take some. I worry how good it is/safe... to have extra injectors in charge pipe. It come with the kit when i brought it.I not happy with it. What a good cheap safe way to get more fuel, FMU? one of shop i going to take into for installation they recomment me to get fuel pump.
Originally Posted by 03CivicEX03
^^ i can just walk in and said i need a c clip and they will found it for me? What it actually call? I wondering it is safe using without a c clip?
i've been running mine with no clip for a couple months and it hasn't popped off yet. It also depends on how much u are boostin, cuz the less boost u run the looser the rod will be.
Balut Eating Champ
^^^can someone draw a somekind a sketch please????
I might be needing one too...
C Clip... I think is a washer like metal but forms a C and has a sharp point on edge for locking, and where you can slide it in a round metal bar and it locks itself up? if it is... then I know what you guys talkin about...
I might be needing one too...C Clip... I think is a washer like metal but forms a C and has a sharp point on edge for locking, and where you can slide it in a round metal bar and it locks itself up? if it is... then I know what you guys talkin about...
