not going past 4000 rpm
Old Jul 6, 2004
brad M's Avatar
brad M is an unknown quantity at this point
gone thru the all data tests on vtec code, and it says to replace ECM. does anyone know want the hell is going on with these cars because i see alot of people are having the same problems. any help would be great.
Old Jul 6, 2004
I'm assuming the car is stock. There have been issues with the ecm going out, but very rarely. So you did an ODBII diagnostic and it says replace the ecm? It might also be the vtec solenoid, but it's hard to tell. If your car is under warranty, just take it back and have them fix it.
Old Jul 6, 2004
Samari's Avatar
that sucks man, i hope it warrentied though. good luck with that.
Old Jul 6, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
4000 rpm is limp-home mode. Something is telling the ECU to go into this safe mode.
If the ECU is indeed bad, you are running on the back-up chip. Honda ECU's have a fail-safe. What codes are you getting?
Old Jul 7, 2004
SuperFrankie's Avatar
SuperFrankie should not be trusted
i have to replace the ecm in my 97 ex my tranny isn't shifting right and it was traced back to that
Old Jul 8, 2004
KaZeLL's Avatar
KaZeLL will become famous soon enough
do me a favor and check the oil...and pm me to let me know if it was empty....
Old Jul 10, 2004
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
I had the same problem and it was the crank sensor broken.
But the computer does the same if any crucial sensor is bad.
Is like tinman said is on a safe mode
Old Jul 10, 2004
brad M's Avatar
problem solved :)
finally found out what was causing my CEL coming on and not going over 4000RPM. CEL code was P1259 vtec melfunction. went trough all the trouble shooting step by step and was getting mad that everything was checking out fine but said the computer needed to be updated or replaced. after hours of trying everything i finally pulled off the valve cover to inspect rocker ***. turns out that on the intake side of rocker's by cyl. 4 on top of rocker ***. is a 14mm bolt that blocks off a hole for oil passage for vtec. the bolt back out letting the pressure bleed of and causing CEL to come on. finally i can rev out with no problem and enjoy my tuning that i did.
Old Jul 11, 2004
tinman's Avatar
Interesting cause.... have to write that one down. Thanks for posting that.
Old Jul 11, 2004
KaZeLL's Avatar
nice glad you solved...
Old Jul 11, 2004
Hatorade's Avatar
SPLAT!!!
Hatorade is an unknown quantity at this point
^^^ yea thats really good to know. i need to save this post just in case glad to see it was an easy cheap fix.
Old Jul 14, 2004
tugboat's Avatar
tugboat is an unknown quantity at this point
i hve 2001 civic ex and got the same code P1259 and my car revs only to 4000rpm and won't let it go over 80mph (it sucks) Brad M was your car a 2001?. I guess i Might have the same problem u had.
SimpleUser
Apr 24, 2021 02:54 AM
loosescrew84
16
Aug 11, 2015 07:08 PM
Green02civic
Jul 27, 2015 10:48 PM
brennov8
Jul 13, 2015 12:57 PM
Jul 12, 2015 11:54 AM
