Hey guys....I need the diminsions of a stock wing to install KTR II wing!
Hey guys,
Just as the heading says, Im going to install a KTR II wing on my 02 civic...two door.....and unfortuantly the car doesn't come with a factory wing so I have to start from scratch. If anyone can provide the diminsions of their stock wing, I would really appreciate it...that or point me to a place I can find out. Thanks!
i'll try to help out the best i can:
Kaminari fits in your factory holes (which you dont have) plus i think you have to drill a few more.
here's the instructions for installing the factory wing:
Tools you need: Phillips Screwdriver, Drill, Tape
- Use the plastic shims that are provided with
the wing to measure the wing against your trunk.
- If there aren`t any, try to conjure up some
with some tape or cardboard and a screw.
- After placing the wing against the trunk, tape
the ends of the plastic shims.
- Use a small drill bit to drill pilot holes
through the plastic shims. Dont forget to drill
for the wire, if the wing has a brake light.
- Use the proper size bits to drill the holes in
your trunk.
- Fit the spoiler, route the brake light, and
then tighten the screws.
- Tap the spoiler brake wire to the brake light
wire in the trunk.
- You should be done
your trunk.
wire in the trunk.
WIDTH 12 Inches
BOLT TO BOLT (FRONT) 45 3/4 Inches
LENGTH 52 1/2 Inches
BOLT TO BOLT (REAR) 45 1/4 Inches
HEIGHT 5 1/2 Inches
FRONT BOLT TO REAR BOLT 2 1/2 Inches
Note: These are the dimensions for the factory spoiler.
Hope this helps!
Thanks so much! You've been a big help. Ive been looking all over the site and the internet to find it. I couldn't have done it without you. Tommorow the car goes in for sure to get the wing painted and installed. Thanks again.
Youshoe
May 22, 2015 09:36 PM
