Question about Automatic Transmission Fluid Change?
Old Jun 24, 2004
streetglower's Avatar
Arrow Question about Automatic Transmission Fluid Change?
First I was wondering if anyone Knows what to torque the tranny bolt too when putting it back on? Also do you have to use Honda tranny fluid? Can I use royal purple tranny fluid? And one last question, when I remove the bolt, is it necessary to buy another one, or just reuse the old bolt? I know I always buy a new bolt and washer when changing the oil, just was wondering about the tranny fluid. Also how much is the tranny fluid from honda?
Old Jun 24, 2004
What I am thinking is buying 3 quarts of Synthetic royal purple and then 7 6 quarts of honda fluid and drain it 2 times with honda fluid then using royal purple fluid at the end.
Old Jun 25, 2004
Anybody???
Old Jun 25, 2004
jahernandez's Avatar
jahernandez is an unknown quantity at this point
honda fluid...
Pretty sure you have to use Honda ATF for the auto tranny, the tranny will shift like poo with other stuff, but for manuals I think you could use something like Redline MTL...just my 2 cents...
Old Jun 25, 2004
Sickboy's Avatar
Sickboy will become famous soon enoughSickboy will become famous soon enough
I have a manual, but with my experience on draining/refilling a few other people's autos, the synthetic didn't make a difference. Maybe for high heat, racing conditions, but if its a daily driver I couldn't justify the cost. If it were me, I'd just flush with Honda's ATF, but more often.
Old Jun 25, 2004
So I can use the royal purple ATF?
Old Jun 25, 2004
Sickboy's Avatar
Of course you can. Then again, you could also use 10-30 motor oil but its missing the additives. See if you feel any difference.
Old Jun 25, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Whatever you use, the key is to change it often, NOT at 100,000 miles. I change my oils/fluids every 20k, except engine oil, of course.
Old Jun 25, 2004
Ok well here is my next question, when I change it is it necessary to buy another bolt, or just reuse the old one. I ask because I always buy a new bolt when changing the oil, thought doing this one too. And also do you fill the new fluid through the dipstick hole.
Old Jun 25, 2004
tinman's Avatar
Tranny bolt torque is 36lbf-ft, and use a new crush washer. Yes, it is filled through the dipstick hole. (closes service manual)
Old Jun 25, 2004
So I dont need to replace the bolt, just the washer. When I take the bolt off, the washer will be under it just like the engine drain bolt. I know I am asking a stupid question, but I have never drained the tranny fluid before.
Old Jun 26, 2004
tinman's Avatar
Correct.
mattdoc
Mar 14, 2017 12:10 PM
sysblack
May 13, 2015 08:55 PM
cruisers10
May 12, 2015 10:46 PM
Flipg123
May 8, 2015 01:15 PM
bsmiley
Apr 27, 2015 01:27 PM
