Question about Automatic Transmission Fluid Change?
First I was wondering if anyone Knows what to torque the tranny bolt too when putting it back on? Also do you have to use Honda tranny fluid? Can I use royal purple tranny fluid? And one last question, when I remove the bolt, is it necessary to buy another one, or just reuse the old bolt? I know I always buy a new bolt and washer when changing the oil, just was wondering about the tranny fluid. Also how much is the tranny fluid from honda?
What I am thinking is buying 3 quarts of Synthetic royal purple and then 7 6 quarts of honda fluid and drain it 2 times with honda fluid then using royal purple fluid at the end.
I have a manual, but with my experience on draining/refilling a few other people's autos, the synthetic didn't make a difference. Maybe for high heat, racing conditions, but if its a daily driver I couldn't justify the cost. If it were me, I'd just flush with Honda's ATF, but more often.
Ok well here is my next question, when I change it is it necessary to buy another bolt, or just reuse the old one. I ask because I always buy a new bolt when changing the oil, thought doing this one too. And also do you fill the new fluid through the dipstick hole.
So I dont need to replace the bolt, just the washer. When I take the bolt off, the washer will be under it just like the engine drain bolt. I know I am asking a stupid question, but I have never drained the tranny fluid before.
mattdoc
Mar 14, 2017 12:10 PM
sysblack
May 13, 2015 08:55 PM
Flipg123
May 8, 2015 01:15 PM
