Jacking up car.
Old Jun 21, 2004
jmiester96's Avatar
jmiester96 will become famous soon enoughjmiester96 will become famous soon enough
Jacking up car.
i jacked up my car yesterday only for it to fall down. I put the jack next to the back left tire where there are two notches about 3 inches apart. Is this the right place.
Old Jun 21, 2004
ImPulse's Avatar
luckily it didnt fall on top of you... Read your manual.
Old Jun 21, 2004
Shifty's Avatar
sounds like the right place, how did it fall??
Old Jun 21, 2004
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
Make sure your jack is level with the ground.
I have always put blocks under my car when I'm working on it because honestly I don't trust what Honda gave us, what they call a jack. (Now a day almost all compact cars have bad jacks.)
IMO
Old Jun 21, 2004
jmiester96's Avatar
i was usin a hydrolic jack and thas where i put it cus thas the only place i can see that would be it, thers no markins anywhere else except for a notch 3 inches long in the front and back on each side so i guessed that that was it. Anyway to make the jack put its force on a larger area i put a wrench on top of it and i was liftin it up and my tire was almost off of the ground and it just fell completely down.
Old Jun 21, 2004
jmiester96's Avatar
Can someone tell me where the right place to put the jack is, was i right?
Old Jun 21, 2004
EManEX's Avatar
Wait you put a wrench in between the car and the jack? Is that correct?
Old Jun 21, 2004
jmiester96's Avatar
yea, the jac i was usin was only about the size of a nickle no the top
so i did that to focus the surface area
Old Jun 21, 2004
EManEX's Avatar
Ok... Now I know what you where using; I have one of those too.
DON'T use that one on the side of the car and PLEASE don't put a wrench there, LOL. Try to find a place on the frame under the car right behind the tires. Make sure is part of the frame or a support of the suspension.
Old Jun 21, 2004
EManEX's Avatar
Anyways what are you trying to do? Why not just use the one that came with the car?
Old Jun 21, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
yup happened to me too. thank god the car didnt fall on me. i was jacking up the car with the stock jack. the jack began to tip over and the car kinda slided forwarded and fell back on the ground. the weight of the car totally bent my jack. i now cary a small 2 ton "big red" jack in my trunk. it works much better and fits in the same place as the factory jack. only 20 bucks at autozone!
Old Jun 21, 2004
jmiester96's Avatar
yea so the closer i get to the tire when i jack up my car the better
Old Jun 21, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
happen to me and friend when switching wheels
i was on a slight incline thou( stupid)
bu tbent the jack and went to junk yard and got an Acura one
sexy color and even looks stronger than our POS factory ones
why would they cut cost material on that
Old Jun 21, 2004
jmiester96's Avatar
Old Jun 21, 2004
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Sounds like you used a bottle jack.
If you plan on working on cars a lot, may I suggest you invest in a floor jack and jackstands.
Old Jun 22, 2004
jmiester96's Avatar
i have a kit will there be a problem with me gettin the floor jack under my car??
Old Jun 23, 2004
EManEX's Avatar
No, no problem. Like I said just put the jack behind the tire. Look where you put it, you don't want to bend anything. Also It would be a good idea to put jack-stands or at least some blocks or 4x4 under the car just in case.
Old Jun 23, 2004
XxSoVeReiGNxX's Avatar
Here is a picture of behind the front *passenger* wheel well. I'm guessing where that extra stuff is, is where you jack it up
please excuse the dirtyness. I take that during the winter
Old Jun 23, 2004
EManEX's Avatar
I'm assuming that too. But the problem is that he has an old hydraulic jack with a support on top of just slightly bigger than a quarter. I suggest putting it under the car behind the wheel where the suspension is. Behind the brakes but to look and try to put it some plce where he won't break anything or bent anything. (like on the frame)
Old Jun 23, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Fvck the Honda jack. We should have a TSB on that. I was jacking up my car one day, on a level driveway, and the base of the jack started to bend. luckily the car wasnt too high off the ground, only the body, not the wheel. But either way, that was some shyt.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
mjdiaz89
Jun 21, 2016 09:26 PM
EngiNERD
Aug 12, 2015 09:20 AM
Q-Bert
Jul 19, 2015 09:09 PM
BootyDo
Jul 7, 2015 06:06 AM
