Return Line...
Old Jun 14, 2004
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
Return Line...
Im getting a new return line for my SF turbo kit, would any of these fit...
Some of the require threded fitting, can i replace the SF one with threded ones??
ATP
Id really apreciate some help..
Old Jun 14, 2004
fuchs's Avatar
fuchs is an unknown quantity at this point
I don't see any reason that you can't replace the SF one with that. Just buy the right size flanges that will match your line.
Old Jun 17, 2004
Could i weld this falnge to the oil pan so i could use a stainless steel line ??
here's what i plan on using...
(2) Flanges http://www.atpturbo.com/Merchant2/me...de=ATP-FLA-009
(2) Fittings http://www.atpturbo.com/Merchant2/me...de=ATP-OIL-007
(1) Line http://www.atpturbo.com/Merchant2/me...de=ATP-OIL-020
Old Jun 17, 2004
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
yeh
if you want to
there are a good number of ways to do it. Just depends on how much you wanna spend. I have Earls fittings.
The only real thing to worry about is making sure the turbo sits higher than the pan where the oil will flow down. ( works on gravity, not pressurized like feed)
Old Jun 18, 2004
any more feed back........
and what material is the EX's oil pan made of?? steel or aluminium??
Old Jun 18, 2004
RiceRocketeer's Avatar
Custom Titles are played out
RiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura aboutRiceRocketeer has a spectacular aura about
EX is aluminum
LX is steel
Old Jun 19, 2004
Anyone know if a 18' line would be long enough, i've got the SF kit and the line they give you is 21', so i dont know if it would reach.........
Old Jun 19, 2004
player1002's Avatar
player1002 is an unknown quantity at this point
Probably, I had to trim a few inches off of mine for it to fit better. I guess it depends on where you drill your hole but I would assume 18" is enough.
Old Jun 21, 2004
HyaBoosta's Avatar
i thought SF was making a fuel rail that was built for a return fuel line?
Old Jun 21, 2004
taz757's Avatar
I thought that was either DH Racing or ExoSpeed?
runawaykinms
15
Mar 22, 2019 10:32 AM
cferry7
Oct 3, 2015 04:33 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
bashea
Sep 15, 2015 04:59 AM
Jrosa
Sep 14, 2015 08:24 PM
