Return Line...
El Pinche Turbo Mexicano
Return Line...
Im getting a new return line for my SF turbo kit, would any of these fit...
Some of the require threded fitting, can i replace the SF one with threded ones??
ATP
Id really apreciate some help..
ATP
Could i weld this falnge to the oil pan so i could use a stainless steel line ??
here's what i plan on using...
(2) Flanges http://www.atpturbo.com/Merchant2/me...de=ATP-FLA-009
(2) Fittings http://www.atpturbo.com/Merchant2/me...de=ATP-OIL-007
(1) Line http://www.atpturbo.com/Merchant2/me...de=ATP-OIL-020
yeh
if you want to
there are a good number of ways to do it. Just depends on how much you wanna spend. I have Earls fittings.
The only real thing to worry about is making sure the turbo sits higher than the pan where the oil will flow down. ( works on gravity, not pressurized like feed)
if you want to
Anyone know if a 18' line would be long enough, i've got the SF kit and the line they give you is 21', so i dont know if it would reach.........
Originally Posted by HyaBoosta
i thought SF was making a fuel rail that was built for a return fuel line?
jackoncruzpr
Sep 29, 2015 07:59 PM
