Fixed: Can't fit new brake pad! Piston is too far out...
Old Jun 1, 2004
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Exclamation Fixed: Can't fit new brake pad! Piston is too far out...
So here I am changing my front brake pads. The piston is TOO far out (because the old pads were 90% worn out)... am i supposed to push in the piston with a vise clamp? What if this is too darn hard? Any easier way to push the piston in so i can fit my brake pads?
Thanks,
ak
edit:
Then take the C-clamp and push the piston back in by clamping the back of the piston cylinder and the face of the OLD inner pad. Once done, remove the inner pad.
http://www.7thgencivic.com/forums/sh...d.php?t=153982
What If that doesn't work? I've bled the brakes a little, but it's still damn hard???
Last edited by ak; Jun 1, 2004 at 09:43 PM. Reason: Nevermind.. problem fixed with Mr. breaker bar!
Old Jun 1, 2004
irishtemper's Avatar
irishtemper has a spectacular aura aboutirishtemper has a spectacular aura about
My brakes were worn to the rivits almost had to replace the rotors and i got some new ones but not ceramic, wears down the rotors quicker. I just pushed the piston in with my hands and had no problems,,,,,,,,,,, make sure you take the cap off of the master cylender, no need to bleed them after you do them just don't hit the brake pedal with the cap off
Old Jun 1, 2004
ak's Avatar
ak
Retired Mod
Thanks for the tip. My dad was around and decided to help me out... he used a breaker bar to push the piston all the way in. Man, did it look painful or what...
Anyway, this is the second time that I've replaced the brake pads.
1st time @ 12,000 miles (OEM's down to 1/3)
2nd time @ 55,000 (ProACT worn down to 1mm!!!) + rotor resurfaced
Hopefully these Raybestos Noise Solution will last me at least 40,000 miles. I did not have the rotor resurfaced... I know that I should have, but didn't feel like fighting the No. 3 phillips screw.
I'll probably replace the rotor in the next brake change because the OEM's will probably be heavily warped by then. Thanks to Greg and Boilermaker1 for your DIY's~!
Greatly appreciated...
ak
Old Jun 2, 2004
dru106's Avatar
ThE CoRRupToR
Have u tried using this???
http://www.7thgencivic.com/forums/at...chmentid=30266
Old Jun 2, 2004
ak's Avatar
ak
Retired Mod
If I had it, I would have used it. What's that called anyway?
Old Jun 2, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Breaker bar? WTF? It should of went in with just a simple c-clamp. I would change the calipers fi they were that hard.
Old Jun 2, 2004
tfnaaf's Avatar
BLDNPSI Mod
if it took a breaker bar to push the piston in be prepared to rebuild/replace the calipers. If the piston went in that hard that means that it most likely will come out the same way... HARD!
Old Jun 2, 2004
civicfreak84's Avatar
civicfreak84 is an unknown quantity at this point
where do you get that clamper that will seperate the caliper
Old Jun 2, 2004
dru106's Avatar
ThE CoRRupToR
I work at auto shop and this truck just came in sellin us tools and i found it. Only costed me $5, but im pretty sure u can get it at auto zone or any other auto store
Old Jun 3, 2004
ak's Avatar
ak
Retired Mod
Trust me, the piston was a challenge!
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
Star1967
Jun 8, 2015 04:23 AM
rhvic
May 22, 2015 03:06 PM
ayoitzjulesdx98
May 14, 2015 08:29 AM
bsmiley
Apr 27, 2015 01:27 PM
