NEED HELP in factory stereo wiring...
Old May 26, 2004
maxxam25's Avatar
maxxam25 is an unknown quantity at this point
Question NEED HELP in factory stereo wiring...
can someone help me label the wiring harness for the stock cd player for 01 civic coupe and where can I buy the wiring harness?
Old May 26, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Unnecessary. The wiring harness you will buy will plug onto the factory radio plug. Match the colors up on the new harness to the ones on the new radio's harness. Wire them together, then you plug them into the stock plug/harness and radio respectively.
Old May 26, 2004
vicn77's Avatar
vicn77 is an unknown quantity at this point
you can go to bestbuy or circuit city...if you have an alpine, pioneer, jvc, sony ccity will have a harness to your car and the headunit so that you just plug the two harnesses together, therefore you don't have to solder any wires together or use crimps
Old May 26, 2004
Wiring harness should come with the radio. There's a seperate harness that you connect to the stock plug. Buying one of the one's at circuit city saves you the 5-10 minutes it takes to wire the new harnesses together. But, usually, it costs more. It doesn't work any better, but it saves a little time.
Old May 27, 2004
maxxam25's Avatar
are you guys talking about the stock or an aftermarket head unit?
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
zeshan7616
Sep 15, 2015 12:24 PM
J-Fly
Sep 10, 2015 08:39 PM
