Help me I have made f up miss?
Old Nov 8, 2001
viper775's Avatar
viper775 is an unknown quantity at this point
Ok, I started painting the Honda cover over the engine red, but I have made a miss of things. Theirs bubbles of paint and levels and levels of paint. How can I smooth it out? Sandpaper?? Any tips would help.
Old Nov 8, 2001
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
the worse case is u paint the whole valve cover !!! but u can use some real fine sandpaper to smooth it out !!!
Old Nov 8, 2001
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
If it looks real bad, just put some coats of primer on it, and redo it the right way.
Old Nov 8, 2001
viper775's Avatar
Ok I'll sand paper the hell out of it then pamier it and redo it.:shady[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Nov 8, 2001
PK2K1's Avatar
PK2K1 is an unknown quantity at this point
u gotta clean it real good b4 u start... with grease remover or something like that.
Old Nov 8, 2001
blueracer's Avatar
blueracer is an unknown quantity at this point
Your layers are too thick. You need to strip the paint, then sand it down. After that reprimer it. Then, you put your layers of paint on very thin. It should look like a very thin layer of powder. Spray it from about three feet away, and do it lightly. Repeat this until you've got about 5 or 6 layers on there, and go over it with clear coat. This should help you. I think I have a picture of mine in member rides.
Old Nov 8, 2001
DarkCivic's Avatar
DarkCivic is an unknown quantity at this point
Make sure your using high-temp paint & primer.
Old Nov 8, 2001
EvilTwin's Avatar
EvilTwin is an unknown quantity at this point
I didn't use primer and I just washed the piece off before I painted it. Hrmm...hopefully nothing bad happens. It looks pretty good not bubbly.
Old Nov 8, 2001
SOHCScreamer's Avatar
SOHCScreamer is an unknown quantity at this point
dude, you gotta know how to paint right. start with primer, lightly, let that dry and reaplly untill its covered right, then paint it with a light coat and let dry. repeat until it looks perfect. the most important thing to remember is to paint a little at a time. very light coats. the reason why you got bubbles and uneven layers is because you painted the whole thing at once. i had the same problem with model cars.
let me know how it comes out.
Old Nov 8, 2001
anibal's Avatar
anibal is an unknown quantity at this point
3 feet away??? Isn{t that too far???
OptimisticWay
Sep 18, 2015 09:37 PM
Mc7602
Sep 17, 2015 02:01 PM
Bricoleur
Sep 9, 2015 12:23 PM
NROD315
Sep 4, 2015 09:22 PM
