Urethane engine mount inserts
Old May 5, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
Question Urethane engine mount inserts
Are these any good? I sometimes think I'm gonna break my engine mount or axle or both. I do drive hard sometimes... would this help my mounts survive longer?
Old May 5, 2004
Quijano187's Avatar
The Evil Genius
Quijano187 is on a distinguished road
Urethane engine mount inserts , they have these for our engine now? do they have poly brushing too for our car ... does anybody know?
Old May 6, 2004
Civryder02's Avatar
Civryder02 is an unknown quantity at this point
if you think your gonna break your axles then upgrade them .. driveshaft shop makes stg 1 axles for our cars. 425 shipped ... i'm getting them for my turbo setup
Old May 6, 2004
robbclark1's Avatar
Retired suspension supermod.
you think your JDM wing is gonna break your motor mounts or axles? Please. some of us have driven harder during races and have no problems. Unless you are boosting or putting down some serious HP or worried about weight transfer while racing, you have no need for urethane motor mounts.
BTW There aren't any out for our engine. They have to be custom made or you can fill a set of OEM ones. Someone has done that on this site with a diy and pictures so search for it if you really think you need them.
Quijano187:
ES and prothane should have bushings for the control arms and sway bars.
Old May 6, 2004
umm.....ooooooooook.......... you really didnt need to go to the JDM wing thing..... but anyway..... I'm just concerned and curious.... thats all.
Old May 6, 2004
robbclark1's Avatar
I was just messing with ya. Your car was built to handle most of the things you can throw at it. Your axle isn't going to break unless you hit something.
Old May 6, 2004
Civicious's Avatar
Civicious is an unknown quantity at this point
I've replaced all of my motor mounts. The front one near the radiator twice! I would love to see an aftermarket solution.
Old May 6, 2004
robbclark1's Avatar
What are you doing to make your motor mounts fail? A bunch of us race on the stock ones with no problems so far.
Old May 6, 2004
Civicious's Avatar
I honestly don't know. My former mechanic said my take offs were likely too hard. Maybe AZ's terrible, always under construction roads could have contributed as well?
I haven't done any performance mods. I have an 01 Civic DX.
Old May 6, 2004
robbclark1's Avatar
Yeah i read you have a DX with no mods. I drive on shitty roads here in baltimore, have raced in a few autox's and haven't had a problem. hmmm. It isn't like your DX has massive amounts of torque....
Old May 6, 2004
Civicious's Avatar
I'm with you. I don't understand it either. I didn't buy the reason my mechanic gave me.
The front one going out twice could have happended when I was in the process of swapping my motor out. My friends claim it was already broken though.
I also drive an automatic if that makes a difference?
Old May 6, 2004
OK, thanks. Thats reassuring.....
Old May 6, 2004
CarbonFly's Avatar
ah yes, my motormounts own joo!!!!
Old May 6, 2004
robbclark1's Avatar
fly just likes to show off because he is getting a K20 from a type R so you don't need something like what he posted. If you are really worried then you can buy some OEMs and fill them with polyurethane.
http://www.7thgencivic.com/forums/sh...urethane+mount
Old May 6, 2004
abmerop18's Avatar
Jam out with your clam out.
^ what good do motor mounts do you when you dont have an engine to use them with yet?
Old May 6, 2004
CarbonFly's Avatar
HEY!!!! The engine is on it's way damnit!!!!
Old May 6, 2004
Civicious's Avatar
Nice mounts Fly! Ya spoiled bastard!
J/K
With my track record I almost need the K-20 mounts.
Old May 6, 2004
cdmx's Avatar
Did you guys see that thead I posted a lil while ago
DIY polyurethane motor mounts
Old May 6, 2004
Quijano187's Avatar
The Evil Genius
na cdmx.. i didnt see it could you find it or just explain it a little here ..thanks for any help
Old May 6, 2004
robbclark1's Avatar
http://www.7thgencivic.com/forums/sh...t=motor+mounts
Old May 6, 2004
RobearRacing's Avatar
RobearRacing is an unknown quantity at this point
Check it:
http://www.tornactive.com/pd_energy_...civic_01on.cfm
in stock, ready to rock!
Old May 7, 2004
robbclark1's Avatar
Originally posted by RobearRacing
Check it:
link doesn't work.
Old Jun 1, 2004
RiceBuRNeR's Avatar
Turbo Member
works for me
Old Jun 8, 2004
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
the mount inserts are great. Only problem is that there is more vibration through out the car but lost the wheel hop completely. Motor doesn't move. And throttle responce it better.
Old Jun 8, 2004
Civicious's Avatar
Isn't that hard on the engine to have it completely restrained? I mean in the case of unavoidable bumps or pot holes?
Old Jun 8, 2004
djmota's Avatar
bumps and pot holes should be absorbed by the suspension, not the motor/trans mounts.
Old Jun 8, 2004
Civicious's Avatar
Well in theory you would hope so. I would think the mounts are there for a reason though. Primarily because vibration detroys engines. Aren't bumps and pot holes a cause of vibration?
I don't know about you but I've hit a few pot holes that have slightly hurt my back. I can't imagine what thats doing to an engine without a secondary impact buffer.
Old Jun 8, 2004
djmota's Avatar
stock motor/trans mounts are intended to A. hold the engine and trans in place. and B. to dampen vibrations coming from the engine and keep them from being transmitted to the inside of the car.
When your suspension bottoms out the hit goes directly to the body..and your back. The engine and tranny are not affected by this.
Old Jun 8, 2004
Civicious's Avatar
I think were missing each others point. Ah, well!
Old Jun 8, 2004
Bjmayo523's Avatar
Bjmayo523 is an unknown quantity at this point
DJMOTA is correct. I also have suffered from the front motor mount being shot. Thank god for extended warranty. Yes the urethane bushings are out for the engine/trans and you can use the bushing kit for the si for the rest of the vehicle. I would like to do it for my whip, but unfortunately I GOTS BILLS. The factory bushings are soft to keep cost down too. If you look at them they arent even complete, they are a rubber disk with a slab of rubber in between. Its nasty.
