Need Help: Vinyl installation
Old May 5, 2004
Tre's Avatar
Tre
Tre is an unknown quantity at this point
So I got the bright idea to try and install vinyl to replace the carpet in my trunk setup. I have a false floor built from 1/4" mdf. I've tried tacking the vinyl to the underside but I noticed that it needed some type of adhesive to keep it smooth. I tried usung Elmer's wet cement , all it did was make the vinyl bubble up instead of help smooth things out. to top it off, the wet cement didn't even stick!! Someone please help. How do I make this stuff stick to the mdf smoothly?
Old May 5, 2004
WhiteRabbit's Avatar
go to your local neighborhoodfriendly upholstery shop andask for a good spray adhesive
Old May 5, 2004
Tre's Avatar
Tre
I checked out sounddomain.com, some of the installers suggested using a spray on adhesive. I'm going to the hardware store now to try this. Hopefully I will have everything ready by tonight and will post some pics.
Old May 5, 2004
Tre's Avatar
Tre
thx white rabbit
Old May 5, 2004
good luck, I hate vinyling. if you have toomany curves to conform to, a blow dryer should help.
if its just a flat surface, youll be done before you know it!
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
