Deck doesn't turn on
Old May 2, 2004
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
I'm having problems with my aftermarket JVC deck, I hooked up my stereo system(one type R sub, and a 700watt amp) My rear speakers were cracking so I pulled out the center peice so I could look at the wires, and suddenly all lights and my deck shut off. I tryed to reset the deck and it still wouldn't work. I took apart the wires, and rewired them. Checked all fuses. Everything was good. Does anybody have any Idea's?
Old May 2, 2004
MegaHurtz's Avatar
Did you check the fuses under the hood?
The one that comes to mind in this case would be the fuse labelled Battery (80a).
I don't really have a frame of reference here, but it sounds like there is a good chance that it is this fuse.
Old May 2, 2004
Marcus's Avatar
I will check. thanx A lot. I will let u know
Old May 2, 2004
Marcus's Avatar
It didn't work, does anybody have any other Idea's?
Old May 2, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
fuse labeled "backup" under the hood maybe? It sounds like you have a short somewhere and it blew a fuse.
Old May 3, 2004
Marcus's Avatar
Right on brother. It worked ..But now I have another problem.. when I turn my car on my cd player powers up, then u hear a bump from my sub. you look in the trunk and the sub isn't flat across, It is extended upwards. How do I remedy that?
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
OPGForce
Exterior DIY
125
May 20, 2019 04:11 PM
mohawkboom
67
Aug 25, 2015 12:28 AM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
GhettoCivic
Nov 12, 2001 03:15 PM
