The 3rd of three
Old Apr 25, 2004
fonto's Avatar
The LA Clipper
Question The 3rd of three
So I want to upgrade the power wire to the alternator, and my question is where is a good place to screw it in on the alternator? I would assume around that little brass piece where the factory wire comes from ...but I don't see a screw. Also, my plan is to leave the factory power wire, so what gauge wire should I use to add a wire directly to the battery?
Do I need to include any fuses between the alternator and the battery???
thx,
fonto
Old Apr 25, 2004
WhiteRabbit's Avatar
always a good idea to fuse the line, id use 4 gauge. if you buy some 2 or 0/1, you should have plenty of 4 gauge lying around
id definitely screw it into the same place the factory wire is. itll be a tight fit, but itll work. the plastic unclips easily enough, revealing the bolt that holds the factory wire.
Old Apr 25, 2004
fonto's Avatar
The LA Clipper
Thanks WR...I assume an 80 amp fuse would be ok...or higher?
Old Apr 25, 2004
I used 80 amp, myself. figgured if tha alternator is only rated for 70 amps....
hell, my battery isolator is only rated for 35 amps, and its still kicking strong!
Old Apr 26, 2004
HondaLuver's Avatar
Its a celebration bitches!
4 all the waay man...
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
BBrosario
Sep 17, 2015 07:51 PM
sermold
Aug 30, 2015 04:21 AM
06Si_Girl
Jul 12, 2015 12:08 PM
