kamikaze header do u have modifications
Old Apr 24, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
On the kamikaze header do u have to modifications or is it just a bolt on?? Thanks
Old Apr 24, 2004
RiceRiley's Avatar
RiceRiley is an unknown quantity at this point
I don't know much about the kamikaze headers but I heard that there is no modifications for them. I know that obx headers have modifications. sorry if I didn't help you out.
Old Apr 24, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
I just dont know how to put them on.. SO any help would be nice tools how to do it I will give points out thanks..
Old Apr 24, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
PLease anyone how much torke I need plz i need ur help ??? thanks
Old Apr 24, 2004
hondacivicd17's Avatar
hondacivicd17 is an unknown quantity at this point
19 ft/ibs
Old Apr 24, 2004
if you have any more questions just let me know
Old Apr 24, 2004
civicvtec1ps's Avatar
Search and Learn
DIY Header Installation.
http://www.7thgencivic.com/forums/sh...ght=DIY+header
Moved to Tech Stuff
Old Apr 24, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Ok thanks guys sorry about me being dumb I just been up for 27hrs cuz of work.. But one more thing My dad said I need new gaskets or sumthing is that true????
Old Apr 24, 2004
I got a new gasket to be safe. But you probably won't be able to get the bolts off. I tried with all my strength and broke my first socket. Got a new one and rounded off the bolts. Good luck.
Old Apr 24, 2004
HondaBrad01's Avatar
HondaBrad01 is an unknown quantity at this point
The one thing I found was, the OEM header has the nuts welded to it. So when you take it off, you dont have anything to bolt the aftermarket header to the downpipe/cat with the existing bolts. At least I didnt anyway. I had to go to the hardware store and buy some nuts and washers that fit the spring bolts (??....sorry I dont really know what they're called). It looks kinda janky, but it works for now. I wanna find something more permanent or proper.
Am I the only one that found this? I wonder why the aftermarket headers dont have the nut welded to the flange like the OEM. ??
Old Apr 24, 2004
Well I couldn't get anything off. So I don't know. I don't remember other members having this problem. So do I need to get new bolts for the bottom springs? What about the top ones?
Old Apr 24, 2004
vivid_BLUE's Avatar
make it a habit
vivid_BLUE will become famous soon enough
I used the same old bolts and gasket. Take the old header out and put the new one in. My friend installed mine and it looked very simple.
Old Apr 25, 2004
I used the same bolts and gasket(s). Its the NUTS that I needed. The bolts have to thread into something. The OEM header had the nuts welded to it so you only had to worry about loosening/tightening the bolts themselves. The aftermarket header (Kamikaze) that I have, came with no hardware for the bolts to tighten to. Hence the reason why I had to go buy nuts/washers so I could tighten everything up.
Old Apr 25, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Ok well I will try tomm? I hope 19lbs is all I got to use Let you guys know
Old Apr 25, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
One more thing thanks for everyone that helped me out thanks
Old Apr 26, 2004
CelCUs's Avatar
CelCUs is an unknown quantity at this point
The screws that hold the stock header to the exhaust are threaded on the header itself, no nuts. So you'll need to go to the store and get some heavy duty washers and a nut that fits the original bolt. You can use all the old gaskets, you may need to shave off a little from the stock gasket to make it fit on the Kamikaze. Other than that it's just bolt on . . . you'll also need a MIL eliminator or an 02 sensor to get rid of the CEL.
Old May 9, 2004
Robert_K's Avatar
Finally a Z Owner
Robert_K is an unknown quantity at this point
Does the Kamikaze Header for the EX manual come with the cat or is it just the header?
UltraHDGames
Jun 8, 2016 05:16 PM
HondaGuy7
Feb 22, 2016 01:00 PM
Cam Diaz
Sep 29, 2015 07:17 PM
carid
Sep 28, 2015 10:13 AM
anubis62
Sep 27, 2015 12:56 AM
