DIY: Hood rattle repair.
Old Apr 24, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
Ever since i got my car the hood would rattle. If I turned the rubber stoppers then it would stop but the hood stuck up too far. Heres what i did. The end result is no more rattle and the hood is flush with the fenders.
I took a length of black electrical tape and wound it around the catch latch located on the underside of the hood about 5 times. The result was a solid latching of the hood.
Old Apr 24, 2004
redvtec04's Avatar
VTEC MASTER
Cant find a pic though.
Old Apr 24, 2004
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
For future referance, the tape may eventually wear though and require replacement, other than that, good call.
If the tape does wear through, I'd get a roll of the clear-duct-tape and try it out, seems to be tougher than any other tape I've used under my hood...
Old Apr 24, 2004
redvtec04's Avatar
VTEC MASTER
maybe some thin aquarium tubing slit up the side then placed on the bar?
Old Apr 25, 2004
nivenmk1's Avatar
That would be good 'n tough.
You could also go down to your local ACE hardware and look for some of that reinforced plastic tubing; has nylon string in it for better wear characteristics...
Also if you dribble some superglue in the slit and let it get good and glued it should never come off... I do the same thing to protect the A-arms on one of my RC cars (it does 0-62 in about 3.5 seconds) that sees a lot of offroad high speeds...
Niven = hobbiest
Old Apr 29, 2004
JoeyOKC's Avatar
http://ackakaka.ytmnd.com
JoeyOKC is on a distinguished road
good work. just the thread I was looking for.
Old Jan 14, 2012
inifiniteblur's Avatar
inifiniteblur is an unknown quantity at this point
Re: DIY: Hood rattle repair.
GOD this has been driving me freakin crazy. just did the electrical tape fix and it worked like a charm. have any sugestions for an exhaust rattle that seems to be coming from nowhere? i've tried exhaust wrap everywhere i thought it could be rattling but havent fixed it yet. it only comes around 1700 to 2xxx rpms
Old Jan 14, 2012
MindBomber's Avatar
Live for the Twisties
that sound like your cat heat shield, remove it, clean off the rust and give it a coat of high temp paint, re-install.
Old Jan 14, 2012
i just saw a post from gearbox that shows this http://www.hondaautomotiveparts.com/...4s5p01_b02.png which part number are you talking about? cuz i got full aftermarket exhaust and the stock cat is gone. like i told gearbox it sounds like part numbers 26 and 27 that are rattling.
Old Jan 14, 2012
MindBomber's Avatar
Yes, those parts that typically vibrate and make the noise, but if you've removed the cat then those parts are gone.
Old Jan 14, 2012
damn. i bought the car with it so i didnt know that. that sounds like where its coming from though. do you think the cat could be going bad or something. it sound like a metallic fart. i can get it to fart on command by putting the car in 3rd at 25mph and giving it a little gas.
Old Jan 14, 2012
MindBomber's Avatar
for me it was a high pitched buzz that occured in a very specific rpm range.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
rovafa2002
Sep 28, 2015 06:57 PM
rnaodm
Sep 21, 2015 12:42 PM
fvckbg
Sep 8, 2015 09:55 PM
